Old 06-30-2008, 11:01 PM
Track License
Rides:1988 BMW 325e
Bimmer325e BD is a New Registered Member
Need mod help.
Hi, my auto tranny took a dump on my bmw...so i decided to dump some money into it and make it a car that i want...so i'm doing the manual conversion as of right now...and i plan on putting some money into the car but i need help, i'm basicly clueless on what to get...I know about the chips(not which kinds are best) and heard of some other things....i don't think im gonna turbo it due to how much it costs.(heard around 3-4k). Another unfortunate thing is my engine has 259k miles...the top end was rebuilt(heads redone/gaskets)....it runs great...i think i've lost topend because i max out at about 105mph...it runs great for now...and was wondering if the time comes...how much a rebuild would be..or maybe a new engine swap could be possible? Just any ideas of tricking out my car...make it faster...would be greatly appreciated...websites/brand names/parts to had would be so helpful... btw my car is a 1988 BMW 325e(supposedly a supereta)....2.7L.
Thanks in advance.
Cars: '88 325e & '67 Camaro RS
Old 07-01-2008, 02:13 PM
Track License
Rides:BMW 325e 1986
pat325e is a New Registered Member
i have a 86 eta so i don't know if the 88 has some of the same components. one thing would be find a 3.25lsd or a 3.73 i am personally am going with the 325 i have heard that 1st is useless with the 373 but i'm not sure of that. as far as chips go the jim conforti is what a lot of people use im not putting it in because im not paying 4.25 a gallon for 93 octane. but those are the basic mods 1.3 Motronic Up-Grade & 2.7i How To - R3VLimited Forums this right up may also interest you.
Old 07-01-2008, 04:05 PM
Track License
Rides:1988 BMW 325e
Hmmm...im seriously interested in the 2.7i conversion...cuz that's what im told is the best...what does this exactly cost? a ballpark figure? and does it really give 180+ hp? and whats it transfer to the wheels???
Old 07-02-2008, 09:16 AM
Track License
Rides:BMW 325e 1984
slawler is a New Registered Member
this sounds like something i want to do to my car. roughly how much hp and torque does it give to an 84 325e?
Old 07-02-2008, 02:00 PM
Track License
Rides:BMW 325e 1986
it all depends im thinking about it to what ive read on other forums some say you get 180-190 and some say over 200. one guy said he had 210 with the eta stroker with a performance exhaust. the cost depends on were you get the parts it probably wouldnt be to hard to find the 325i head in a salvage yard and it probably wouldnt be to high up in cost or you could find a 325i parts car that has the stuff you need. good luck
Old 07-02-2008, 11:36 PM
Track License
Rides:1988 BMW 325e
yea...well i get my bimmer back tomorrow : ) Finally converted it to a stick...stupid auto trans was a nightmare....i read that 2.7i's don't idle smoothly? is that true? it doesnt idle right cuz of the 325i ecu? i think?
Old 07-03-2008, 05:16 PM
Track License
Rides:BMW 325e 1986
idk i dont have it but it might be true. If they say it doesnt idle smoothly u have to make. a ruff idle in a 13b rotory is kinda like a 2 stroke outboard if you know what im talking about it revs then goes down thats my idea of a ruff idle or it could be different like a shaking like one of your cylinder is misfiring. but if you want power cheap thats your best bet. the m50 is a good option but its a grand for the engine and tranny then you need the drive shaft motor mounts and ecu.
Old 07-03-2008, 11:04 PM
austra's Avatar
C.S.C.C. Instructor
Rides:96 328i and 88gt 5.0 86 325e
austra is a New Registered Member
well your super eta is easy to make a 327i swap the head to a 325i head its easyer then swaping the cam and then valve springs, the 84e not so easy only the super E has domed pistons like the I motor cars.all the rest of the E's have dished pistons so you can bolt on an I head but your compression will be in the 7 to 1 range. you can swap all 6 pistons and then put the head on. you can also shave the head about .035 which should rasie the comression to at least a runable number would not recomend the shaving unless you do lots of math to get every thing right. you still need an ecm to run it above 5k to use the I cam
e36 silencer's out, rims,M3 cams sway bars and springs front and rear, zimmermen crosdrilled rotors, comming soon a real intake, exahust, chip. lapped PIR @ 1:36.5 w/o cams ITA E30 325e 1:35.1/ PR 1:45.4
Old 07-04-2008, 02:07 PM
Track License
Rides:1988 BMW 325e
well...i was going to do the 327i swap....but i heard changing out the ecu makes it idle rough...i want my car to still be reliable...but fast...so...what kinda car u got?
Old 07-04-2008, 02:08 PM
Track License
Rides:1988 BMW 325e
did you do the 327i swap on ur 86 eta?
Old 07-04-2008, 10:28 PM
j.amrol's Avatar
Track License
Rides:85' ETA, 86' ETA sport
j.amrol is a New Registered Member
The idle doesn't run rough.. It takes an extra half second on start up if you were to keep your pistons and throw on the I head. Because of the combustion design and piston design.
There's write ups EVERYWHERE! Do you not look?
The basic fact is that if your tearing apart an entire motor why not build it up to what you want it to be?
high compression/ custom pistons cost money, and you could have the I's pistons shaved 2-3mm to work as low compression.
The crank you already have which is a plus, but if your tearing off the head and pulling pistons why not upgrade the crank? and so on and so forth.
How big of a budget are you talking? A manual conversion is a pretty penny at any shop. Done yourself you could do it for well under a grand.
You've got to set goals before you can start your build. Do you want naturally aspirated, or boost?
Lower compression allows you to run more boost and timing at a less grade fuel.
Higher compression you have to run lower boost (if any) with a higher grade fuel.
You have to research and ask yourself what you want to use the car for, a dragster is obviously not reliable.
A street car is obviously not a dragster.
What I'm going for is keeping the Eta head/ pistons (e30 323i head if I can find one) or, I intake manifold, TB. Having it all machined to fit together, and to accept the I's cam, (the valves are 1mm bigger and the springs already drop in).
Keeping my chip, (rev limit set where power drops off) running boost at 8psi to 1bar. My goal is to run 93 octane (available at the pump) with turbo. Simply bump it into the rev limit and shift. Still retaining Low end torque, AND gaining high end horsepower.
The 273, and 293 differential are useless unless you are losing time due to shifts. I would chip it, boost it at 8psi and call it a day running 93 octane. Add an exhaust when you can.
The whole idea is already laid out for you, all of the trial and error is laid out. You just have to decide what you want..
and yes economy cam's are awesome for boost.
Diagnally parked, in a parallel universe.
Specifically integral parts as if a machine we're speaking,
or on drugs and we're peaking.
Living slow but constant.
Seemingly meaningless peices
if thrown stray your whole operation will seize.
No one ever said life was easy.
Old 07-05-2008, 02:39 PM
Track License
Rides:BMW 325e 1984
bimmer325e how much did it cost to do the tranny conversion? what all did you have to get and what not. i have an auto and want to go stick. if it costs under like 700 ill think about it.
Old 07-06-2008, 01:07 AM
Track License
Rides:1988 BMW 325e
well you have to get the pedals, master and slave cylinder, a getrag 260 transmission a clutch kit...a driveshaft..flywheel the lines for the slave ...clutch fork...transmission crossmember rubber mount shift tower boot and knob...cost me 875$ from this company in sacramento, CA...uhm...it cost me 750 for it to be installed cuz he's a family friend...but it will prob be double that...its about 15 hours of labor...
only down side is you have to keep your neutral safety switch glued in the "park" position and hide it somewhere...and you dont get reverse lights...still havent figured out to make it work...but its only been 2 days since i had it...and ive been working..
Old 07-06-2008, 06:39 AM
Track License
Rides:BMW 325e 1984
that sounds like alote of fun.
Old 07-29-2008, 05:53 PM
Rides:85' 325e
SpartanTiger81 is a New Registered Member
Damn I didn't know you could get 200+ horses out of a stroker!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497
