Old 03-18-2008, 08:31 PM
Rides:1986 bmw 325es
scandelousJK is a New Registered Member
- -anyone really good at problems help- -
alright i have a 1986 325es with 220,000 miles on it no leaks, has been rubuilt twice now in the past 50,000 miles. has new cooling system complete, and most the ignition system complete, minus the air idle control, and ignition timing control, and the injectors. alot of sensors look like they should be replaced, and however my valves could have got bent from the last rebuild, but she drove perfect for 1000 miles after last rebuild. now the question is she stopped running with full strength and now i smell gas in my dipstick, my spark plugs have oil on them and are burned out every 300miles, my rpm gauge shut off, and also my car will not idle without putting pressure on the gas pedal unless you pull off the connector on my air/idle valve. either way when i run her and keep the rpms up, she once was very queit with my tek exaust and now she is screaming like a banshee and she eats oil, and sucks gas. any ideas i am at the bare end and cant afford to fix everything at this point but need to get the car running. could it be the injectors, or my piston rings, or something with my timing, maybe mass air flow sensor, or o2 sensor, or anything i havent named? i drove her home from florida in this condtion and it has not gotten worse. im completly lost at this right now and nay help would be very appreciated because i love my car and do not want to have to junk her
Old 03-19-2008, 11:16 AM
Track License
Rides:BMW 325e 1984
slawler is a New Registered Member
does it kick any smoke? if it does my car did that also with the exact same problems. i think when i got it fixed they said it was an injector boot. but im still learning to. if hope that it helps.
Old 03-19-2008, 04:01 PM
Lightbulb new info maybe this is more help
yeah she smokes sometimes when i start her. and sometimes she doesnt, im thinking though that there is some emissions problems that is telling my air idle stabilizer to idle faste rand slower eratically, due to some sensor failure in my emissions....but thats a maybe because soemthing isnt reading and also sending oil into my intake. there is no pcv valve in the car so thats no help, and maybe anybody knows if its a big difference having a map sensor or not, because mine is broke also. and looking deeper theyre is a bundle of wires one is pretty small less than 14 gauge i know, and it runs by my intake on the left side facing the front of the car and runs down by the fuel pump and connects to a prong on my block... any ideas what the hell that wire is maybe a temp sensor, or something fuel related or diagnostic, mine is chewed up and i replaced it and it doesnt help or make things worse whether it is on or off...
Old 04-05-2008, 11:19 AM
imae30driver's Avatar
Rides:bmw,m3,89
imae30driver is a New Registered Member
ok, in my opinion. if you have gas in your oil and oil on your plugs you probably need new rings.. if your burning oil that will destroy your o2 sensor witch will kill your emissions and fuel economy. the need to give it gas to start supports a loss of compression due to bad rings... not to rule out a blown head gasket. you IAC( idle air control) would not cuase this becuase as it gets clogged it would richen the mixture witch you do with the pedal to get it started anyways. as for a pcv systom im not sure if it was fedraly madated in 86 but may have been.. it being clogged may leave hydrocarbons from blowby in the crankcase witch could explain the gas smell on the dipstick or may be sucking up oil and running it back to the intake to foul your plugs.
if you are burning oil theres a very good chance that your catylist may need to be replaced.
Old 04-17-2008, 05:04 PM
yeah, i the head gasket is fine and i checked my valve clearances once more and they are fine, im gonna try to install an o2 sensro soon, but as for the rings i hope its not, people who have looked at it have said they think its either out of time, or i have a vaccuum leak somewhere i havent found yet. if it was the rings i would assume i woulodnt have as much power, which i can still light up the tires, and it wouldnt make too much sense that i get a bit of back fire on my idle. in the back of my mind its the rings but im hopin its got some damn good german engineering and its something else. im about ready to junk it for a 57 bel air though if it is the rings, and no more dtmpower for me.
Old 04-20-2008, 09:09 PM
Track License
Rides:06 760li
wheelrub is a New Registered Member
same issue with my current motor, smell gas in the oil, i KNOW its the o2 sensor though i took off the complete exha. and there was a 1inch gap on one side of the o2 sensors welding bung and on the otherside it was rusted in place...
otherwise i would see NO reason for the car to be running fine one day, then after i mess with the exh it stop running
try your o2 thats what im going to do
Old 04-21-2008, 06:59 PM
yeah thats part of the problem. however today i finnaly got it fixed by taking a piece of sponge and putting it in the hose that runs from my throttle body to my valve cover, and that stopped the leak and she will idle right now, but next stop is the o2 sensor. and then i want to put the ford 19 pound injectors in, would you guys now if my computer will pick up the injectors, and will i need a fuel pressure regulator for that immediatly?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730
