Old 03-07-2008, 09:46 PM
Rides:BMW, 325es, 1986
bmwordrive is a New Registered Member
AFM help
Does anybody know if the M30 AFM swap works on a 325es? cause my car just dies and idles crappy. Does anybody know what else i have to do to make it work? thanks appreciate it
Old 03-19-2008, 08:31 PM
Scarecrow's Avatar
Rides:E30 JPS, E24 635Csi, E21 323i
Scarecrow is a New Registered Member
Hi, i have only found one person who has done a write up on it (having converted an M20 to M30 AFM). Did you swap the guts out of the two AFMs? (the circuit board and springs etc) Apparently thats how you make them work - And a tune of course -
If i can find the site again i will post up a link for you
Scarecrow
E30 323i JPS Cabriolet - Linder Enhanced
Old 03-20-2008, 05:52 AM
Rides:'87 329iS '04 MINI
Kyle B is a New Registered Member
yes, it does work. I have an M30 AFM in my stroker M20. BUT, it is not 'plug and play'. If you're trying to solve a bogging issue putting in an M30 AFM with no other tuning is definitely NOT going to fix your problem. I suggest replacing your AFM with a similar working unit.
Old 04-11-2008, 03:33 PM
Darien28's Avatar
Rides:'87 BMW 325
Darien28 is a New Registered Member
I've done it, no problems. however, if you do it, you'll either be too lean on one end or the other. I suggest lean on the low RPM range, and richer up top.
Ideally, you should run a piggyback to tune it correctly. I believe there is one narrow year range of M30 engines that used motronic 1.0, but the AFM still used a 6-pin connector, so you would need to swap the internals for this to work.
as for tuning, you can initially just play wiht the toothed wheel inside the AFM to adjust the spring tension and you should be able to get it to idle and respond ideally. (blip throttle a bit and see how engine responds). ideally you want it to blip up without any hesitation, and then return to a solid idle.
but back to your issues with bogging... you may want to just adjust the spring tension in your current AFM to see if that helps out at all. springs weaken over time, might want to just tighten it a notch or so. try that first...
E30 1987 325/e 4dr (1998 ~ 2005 - sold)
E36 1995 325/M3 Dinan supercharged (2004 ~ 2004)
E60 2005 530i (2004 ~ 2007 - lease returned)
2004 Impreza STi (2004 ~ 2007 - sold)
2002 Kawasaki ZX-6R (2002 ~ 2007 - sold)
2006 BMW K1200 R (2007 ~ current)
2007 Dodge Ram 1500 (2007 ~ current)
Old 05-11-2008, 04:42 PM
Do the splitsecond conversion
Old 05-11-2008, 06:42 PM
Adjusting the spring pressure will help a bit, but the biggest step that everyone misses with this mod is swapping out the internal circuit board. If you test both AFM's with a multimeter you'll see the resistance values between the AFMs are waaaaaaaaaaay different, and if you don't swap the board over from the old AFM your Motronic is getting signals that aren't even close to what they should be.
As for the Split Second conversion, I'm not really a fan. I spoke to one person a long time ago when it first came out that said his engine (M20B25) ran like poo-poo with it and he could never get it tuned right. I personally put a MAF conversion on an S14 and the dyno showed us a gain of a whopping 1hp, with a LOSS of 1 ft/lb of torque and a power graph with more peaks and valleys than a mountain ridge.
I still think you need to find a good, known working M20 AFM and test it in your car.
Old 05-11-2008, 06:47 PM
YES YES YES! adjustable FPR too
( ( ( davelength ) ) ), it's an old site so it might be gone by now - I know the car is.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727
