| It's a common setup. With any aftermarket shocks, you will want to run aftermarket rear shock mounts, the current ones will blow soon after installing your stiffer shocks. The cheapest aftermarket replacement would be the JTD "Repair Shop" Rear Shock Mounts BE SURE YOU USE ALL THE OEM WASHERS WHEN REPLACING THE REAR SHOCK MOUNTS.
__________________ Cracked Oil Pans: 6 Last one: April 14th, 2008 ![]() "If your fenders aren't rolled, you have bad wheel fitment." |
