| could be your maf going bad. seen lots of pro3 have a similar problem. others had a loose ground . your full throttle /idle switch could be going bad too.
__________________ e36 silencer's out, rims,M3 cams sway bars and springs front and rear, zimmermen crosdrilled rotors, comming soon a real intake, exahust, chip. lapped PIR @ 1:36.5 w/o cams ITA E30 325e 1:35.1/ PR 1:45.4 |
| I 100% guarantee its the fuel pump. Iv said this sooo many times, and it always is. The e30 pumps get clogged really easily, its even happened to mine. I, and everyone else that had the exact same problem. Just take out the fuel pump thats under the car behind the drivers seat and either clean it out and replace the fuel filter, or replace the pump if its on its way out. Look into it, Im sure this is the problem.
__________________ -Andrew |
