Old 02-08-2007, 12:26 AM
Rides:Bmw,325i,1989
kissinger is a New Registered Member
2.8 stroker help
I own an 89’ 325i. It was running rich at start up and leaving black sooty deposits on the back of the car. Figured it needed a tune-up, cap, rotor, and sparkplug wires. A short time later I broke a rocker arm. I unassembled heads and noticed cam was badly scored. I decided to rebuild motor, used my 2.7crank Ross pistons, 272 cam complete head rebuild – larger 1mm exhaust valve, 19 lbs m30 injectors lightened flywheel balanced motor. I also noticed intake didn’t match head very well so I ported intake to match. Ran lean upper rpm, changed back to stock chip. Motor real hard to start and still black sooty deposits smells rich at startup black smoke. Changed coil msd blaster, cap and rotor runs stronger but no change. All parts spec out tps, 02, air bypass, crank pulse, cat don’t work also have m30 Afm to install. I have planed to upgrade to IE fuel regulator could this fix my cold and warm start problem. I believe it runs rich because i have to floor it to start it after many cranks it almost won’t run then it runs and smokes after its warm it runs great?
Old 02-21-2007, 08:38 PM
Rides:Ford, Explorer, 1998
Ole703 is a New Registered Member
Try getting it tuned? What octane fuel are you running? Sounds like your either need a tune real bad. I am unsure of the size of the stock injectors. Try running those. 19lb injectors may be too big. But, you are running a configuration that I have never personally delt with. It does sound like your getting too much fuel and not enough air in the mixture. Good luck and I hope it works out good for you.
"The bitterness of poor quality remains long after the sweetness of low price is forgotten."
Old 02-24-2007, 03:24 PM
Rides:Bmw,325i,1989
running 91 pump, installed afpr and afm it runs real strong great power, starts right up now but still runs rich at idle, went to pretest car to see how its running, hc are to high at idle great through rpm range wont pass smog need to figure this out. will replace wires and o2 soon and intresting that smog shop said cat was working at rpm range i thought it was no good 200,000 miles on it and a rich condition no water vapor i wonder if i even need it at all ?
Old 02-24-2007, 07:28 PM
Fidhle007's Avatar
Drive Monkey, Drive.
Rides:'90 325is, Alpine White
Fidhle007 is a New Registered Member
First of all, try complete sentances... Secondly, what condition is your ICV in?
Old 02-25-2007, 08:51 PM
Rides:Bmw,325i,1989
Well ICV vibrates, 44 ohms outer terminals and 23/21 ohms center outer terminals. AFM intake temp sensor 4200 ohms cold and 2200 warm, seems high according to Bently. Engine light was blinking at WFO seems to run better with stiffer AFM spring tension. Dont know were to go from here except replace wires or 02, can i change to wide ban 02 because i would like to megasquirt soon?
Old 03-06-2007, 09:08 PM
E30stain's Avatar
Sherminator
Rides:'96 323i
if u get it workin fairly well soon post up some dyno figures i wanna know whether its worth the moeny 'improving' my m20 thats sittin in the shed before attatching it to a 325
'is she fucked or is she proper fucked?'
'shes proper fucked'
'ahhh fuck'
Old 07-17-2007, 09:57 PM
Rides:Bmw,325i,1989
Well smog was required and I pre tested at 1500 HC, smog tech told me that I have too much cam overlap (272 cam) and would not pass. Often people come up to me and ask if I stuffed a v8 in here lol. I found info on AFM adjustments here in forums and learned how to change spring tension and CO adj. with Allen key. I went back and made Adj. while pre testing, HC went way down tech thought his computer was malfunctioning lol and reset it. I passed with 7 HC and .01 CO they couldn’t believe it.
I still have a couple problems; my car is hard starting when it sets after warmed up, have to floor it to start? When it’s cold it starts right up, I think the Dme doesn’t know how to open injectors? Think I need correct chip or megasquirt? I have a Bavauto chip and my car pings real bad between 4000-5500 rpm when WFO I think spark timing to advance so I run stock chip. I wonder if I need to change cam timing.
Old 07-20-2007, 01:29 AM
the afro guy's Avatar
professional bum
Rides:1990 E30 327i
the afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master Licensethe afro guy has achieved their Master License
i'd say the problem is in the uprated injectors. usually when you go for higher capacity injectors it's a good idea to use an adjustable fuel pressure regulator. most people run them at 2.5bar when the injectors are first installed to give the ecu a chance to figure out whats going on, then they jump it up to 3.0 bar once
everything is sweet.
could also just be that your injectors are clogged and need to be serviced.
if that doesn't work then maybe your afm is still playing up or might be buggered. maybe find someone that has the same motor as you and try their afm to see if that makes a difference?
having to floor it to start sounds wrong. this isn't a carbie fed car.
the 325i is a little harder to sort out yourself than say a 325e because it runs a different version of the motronic computer. certain things can only be adjusted when it's plugged into a computer. personally i'd take it to a mechanic with all the right gear for tuning m20's and get them to diagnose the problem these things can be an expensive pain in the arse to fix if you're doing it by trial and error
90 327i, keeping the tyre industry running
88 320i vert, resprayed and retrimmed. pics coming one day!
76 320, bunky farm racer
Old 07-21-2007, 12:04 AM
Rides:Bmw,325i,1989
warm start problems
Injectors were serviced (m30), I have IE afpr, upgraded to m30 afm 027 and I upgraded to motronic 380 couple months back 173 acting funny.
I will back off fuel and unplug computer to reset it hopefully this will work.
Thanks for the post
Old 07-21-2007, 08:12 AM
professional bum
Rides:1990 E30 327i
is cool. keep us posted on how it turns out though. i'm looking at doing a few things like that to my car in the near future and want to see what works and what to do when it doesn't!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732
