Old 08-06-2006, 01:31 AM
Yee-ha
Rides:.
uKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master LicenseuKnowSergio has achieved their Master License
DIY: E30 Front Splitter
DIY E30 Front Splitter
I know that we did this on our m3, but its same principal for most e30's with m-tech kit, or even e36 with kit.
First:
Take off your Front Bumper.
Buy your plastic. Yellowpage's should be able to help with that.
We went to a place close to us, picked up 6mm Polycarbonate Plastic Sheet (2m x 70cm) This size will vary on different front bumpers. Cost - $70.
MAKE SUREyou measure the front bar accordingly and leave enough space for cut offs.
Second:
Masking tape one complete side of your plastic sheet.
By doing this you now can draw the splitter onto the plastic with out scratching it.
Third:
Make sure all your mesurements are right, then cut the inner side of the splitter.
Try to cut it to small and slowly sand it down to fit just right. You don't want to cut to much first time and loose it all.
Just hold it up to your bumper flat to find out what needs to be sanded down. (see pic)
Forth:
Now you have made it fit just right, and drilled the holes to connect. By doing this, mount it on and measure how much your want it to pretrude off the front bar.
WE personally just used the masking tape roll and pen. To get a perfect amount all the way around.
Then un-bolt the splitter and cut to shape.
Fifth:
Remove all tape, polish platic and bolt on for last time.
Hopefully these five steps can help you make one yourself. There is an improvement on getting the nose down in hard cornering.
-Sergio
sergio@buddyclub.com.au
BMW E30 M3 EVO II #196 / 500
BMW E46 330ci Coupe
Old 08-25-2006, 01:05 AM
Stevie... my booooi
Rides:E30 M20 2.9lt Stroker
Stevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master LicenseStevin has achieved their Master License
Thanks man... I've been pondering this for a while now
2.9lt 4dr Rightness
Old 09-10-2006, 10:11 AM
leggwork's Avatar
Rides:90 M3 2.5, 89 Spec E30
Region: USA - Rocky Mountains
leggwork is a New Registered Member
good writeup and pics - thanks.
I was also going to use ABS on mine. It is referred to as Haircel and should only be about $40 for a 4x8 sheet of 1/8 to 3/16 thickness.
I have heard that using the chemical MEK on the edges will give it a nice smooth finish (don't know if it works on polycarbonate or not, but does on ABS). I think it slightly melts the plastic so you have to be careful in applying it.
cheers,
bruce
Old 09-19-2006, 06:12 PM
ANDRÜ's Avatar
mooseoftoose
Rides:'87 325
Nice write-up!
-Andrew
Old 09-22-2006, 05:18 AM
SaLto's Avatar
Rides:BMW M5 E34
SaLto is a New Registered Member
One question:
How much efect have that kind of aeromod without te rest of the kit?
By the rest of the kit i mean the aerodinamicaly constructed and made underside, for maximising down force?
Or is that just cosmetic?
Doctor!
Old 09-22-2006, 01:21 PM
Andy47's Avatar
Rides:what I get my hands on
Andy47 is a New Registered Member
Nice write up, and thanks for sharing!
Andy 47
Old 09-23-2006, 08:14 AM
ANDRÜ's Avatar
mooseoftoose
Rides:'87 325
Originally Posted by SaLto
One question:
I would say alittle of both. It certainly will help at really high speeds, but wont do too much at lower speeds. It does look VERY nice though
-Andrew
Old 09-26-2006, 02:40 AM
SaLto's Avatar
Rides:BMW M5 E34
AHA!
Doctor!
Old 12-28-2006, 04:37 AM
Fidhle007's Avatar
Drive Monkey, Drive.
Rides:'90 325is, Alpine White
Fidhle007 is a New Registered Member
When I went from the stock iS lip to a Rieger lip and splitter there was a noticeable difference in high-speed stability. Until I destroyed my lip and splitter...
Old 06-02-2008, 07:08 AM
StarkeyT22489's Avatar
Rides:87 E30 325ES
StarkeyT22489 is a New Registered Member
how much did it cost u total for everything to make ur own lip.?
Dream as if you will live forever, live as if you'll die tomorrow.
Old 06-02-2008, 09:55 AM
Rides:'87 329iS '04 MINI
Kyle B is a New Registered Member
It's around $75 to $80 to do it, my buddy and I did this about 10 years ago with an 87 'iS.
It's a looks thing for sure, if you look at a real splitter on a race car you'll see that it is angled downward to provide actual downforce to the front of the car. a 6mm wedge of plastic perfectly parallel to the ground isn't going to create any downforce at all. Any 'seat of the pants' improvements you feel would make for great conversation with your psychiatrist
Old 06-06-2008, 02:40 PM
Track License
Rides:1990 325i
N2MYE30 is a New Registered Member
Now thats slick.
Your Current Signature Picture
Old 06-07-2008, 01:19 PM
Oh, and I forgot to metion something:
If you're going to do this make sure you put enough fasteners in the splitter. I lost two fasteners in the middle of my splitter during a trip from DC to Pittsburgh. On the way home I decided to do a short high speed run on a nice open stretch of highway. At about 120mph I felt the front end of the car vibrate, then a split second later saw a black peice of plastic fly over the roof of my car. When I got home all I had left was the two ends still bolted to the front spoiler. Fun stuff
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491
