Go Back   DTMPower BMW Forum > Technical Discussions > E30 3-series and prior
Old 01-08-2004, 02:46 AM
Phunkatek's Avatar
Rides:06 330i
Phunkatek is a New Registered Member
Dumb question about A/C =)
quick dumb question about the A/C in E30's, or all cars for that matter - my friend told me that when you turn on the hot air, with the way that the a/c works in his 325is, what you're actually getting is hot air from the engine. Is that true? I never knew thats how the a/c works...
Old 01-08-2004, 07:15 AM
MaDhAtTeR's Avatar
Throttles ahoy.
Rides:E21 JPS 323i, B6 2.8, E30
MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR
how can you get hot air from the engine? push some in from the exhaust does it?
- Website with full rebuild content coming real soon -
Old 01-08-2004, 09:30 AM
EVOIIIM3's Avatar
S14 Master
Rides:00 Audi S4, 05 Lancer EVO 8
EVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master LicenseEVOIIIM3 has achieved their Master License
Hot air with AC? Isn't AC to CHILL the air?
Now a heater works off of coolant water going threw a radiator in the cabin, the temp knob controls the flow.
the AC is basically a small refrigerator.
Air cooled cars, have "heat exchangers" that take he hot air in chambers around the exhaust.
91 Beyond Sport EVO 2.5l (300hp), too many dam mods!
Updated Web page check it out!
Old 01-08-2004, 10:57 PM
Phunkatek's Avatar
Rides:06 330i
whoops- yeah sorry about that. Yeah the word to use would be when you turn on the heater I guess. Basically when you want some hot freakin air to warm your ass up. Main point just being where the hot air comes from. I guess I always figured the car drew in air and then heated or chilled it accordingly. So it takes hot air from around the exhaust eh?
Old 01-09-2004, 08:31 AM
EVOIIIM3's Avatar
S14 Master
NO!!!!!!!!!
AIRCOOLED CARS!, like VW's Big and Porches, use the exhaust
BMW's use the cars coolant, going threw a valve to the cabin, then the fan pushes the air over the hot radiator creating heat.
If you are going to ask questions, think about what you want help with first, then try to call things by their correct names, it really helps if we know what you are asking about.
Old 01-09-2004, 10:06 AM
MaDhAtTeR's Avatar
Throttles ahoy.
The AC clutch will cut out aswell. The AC system is seperate from the heating side of things.
Old 01-09-2004, 11:23 AM
Darien28's Avatar
Rides:'87 BMW 325
Darien28 is a New Registered Member
are you sure the AC clutch disengages? cuz mine doesn't. I sometimes put the dial in the middle somewhere if i didn't want the air to be that cold...
also, technically speaking... a/c stands for air conditioning... and i guess conditioning can mean cooling or heating... but that's beside the point...
andyways, as for the heater, the air intake is the same as the a/c air intake... right where the wiper blades are. after the air is sucked in by the blower, it either goes through the A/C evaporator or the heater core or both... the red/blue dial controls the flap which directs air to the 2 chambers. the how coolant flows through the heater core and the air is heated by the heater core. this is why u don't get hot air until your car is warmed up. on the cold setting, the air goes through the a/c evaporator which looks like a small fat radiator that has freon/refrigerant flowing inside of it... if the a/c compressor is on, the air will be cooled, if the ac comp is off, then the evaporator is just sitting there at ambient temp, and the air is roughly the same as the outside air temp.
where the hell did your friend get the idea that hot air came from the engine compartment?? if that was the case, wouldn't the air become cold once you started moving due to the airflow over the engine.... >.>
E30 1987 325/e 4dr (1998 ~ 2005 - sold)
E36 1995 325/M3 Dinan supercharged (2004 ~ 2004)
E60 2005 530i (2004 ~ 2007 - lease returned)
2004 Impreza STi (2004 ~ 2007 - sold)
2002 Kawasaki ZX-6R (2002 ~ 2007 - sold)
2006 BMW K1200 R (2007 ~ current)
2007 Dodge Ram 1500 (2007 ~ current)
Old 01-09-2004, 11:59 AM
MaDhAtTeR's Avatar
Throttles ahoy.
If you switch it to heat it will, the compressor wont continue to drive while it's being heated. I cant remember if it is thermoswitch controlled or not. The newer cars with climate control will cut in and out to meet the temperature automatically (sensor controlled). If it's set to 20 degrees and the A/C has been on, it will cut out to adjust the temperature.
Old 01-10-2004, 05:13 PM
Phunkatek's Avatar
Rides:06 330i
Alright guys sorry for all the trouble, but thanks a lot.
Open for Mothers Day Dinner
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737
