Old 07-14-2003, 11:59 AM
bmwmpower1's Avatar
Banned
Rides:1988 BMW 325I, 1988 BMW 325IC CONVERTIBLE
bmwmpower1 is a New Registered Member
Nightmare with a 318 cluster on a 325i help!
Hey Guys,
I needed to change my cluster cause my odometer stopped working with another one I got with the same km at a scrap yard. I put it in and it bolted right on. It went ok for the first couple of weeks. The main purpose why I got a 318i cluster was because the other places didnt have it and its to expensice to buy a new one. And I wanted to change the old one because the MPG guage and the odometer wasnt working. So I did. It went ok for a couple of weeks. Then the service light came on. So I poped the hood and jump the wire from the nagative pin to the other correct pin. The lights reseted to green. So it was ok. Now it cam on again, but when I try to reset it. It seems like its jumpng from lighting Oil Serive, to Inspection lights are red and yellow. And the oil service lights stays on as it doesnt reset anymore. And sometime it jumps too inspection and so forth. I also noticed that the temp guage when the engine heats up abit it moves around, like it twicthes. When I tap the cluster it becomes ok and then start doing it again after abit later. But sometime when it does twitch something it fixes by it self. One time the KM guage to stopped working and after hitting it, It works again. But now its working ok. But still, I also noticed that the guage fuse burned aswell as the starter. I replace them. I dont get it when I bought it everything was ok it happened like 2 weeks later. Is there any way I can convert the 318 so it will be compatible with a 325 cause it looks like the same shit to me... help me guys.. sometime the cars lights go dim too... But after reving it it fixes up, my battery died last night had a boost the lights were dimmed I reved the engine too 5k and it fixed the problem. All this because of the cluster??
Old 07-14-2003, 01:15 PM
Rides:Mazda 323 92
Cyber is a New Registered Member
Pretty obvious that your alternator is old and used up...
get a new one. I dont know about the cluster it self... might not have the same wiring/voltage as the 325 one...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736
