  #16 (permalink)
Old 12-06-2001, 07:39 PM
EricblurM3's Avatar
Rides:Golf Cart
EricblurM3 is a New Registered Member
Originally posted by Nick
Chamois.
Well, atleast I had it so you knew what I meant...lol, now i know.
  #17 (permalink)
Old 12-06-2001, 08:24 PM
Rides:Clownshoe
Rook is a New Registered Member
does anyone here use the california water blade? I use a genuine sheepskin mit I got at B&B, Meguiars car shampoo and warm water. a low pressure garden hose to rinse, and the california waterblade to dry. Its basically a soft squeegee. I have had good luck with it, just make sure you don't catch any dirt in it, or else you could end up dragging it along the paint, same with a chamois tho. Do you use the absorber like a towel?
Rook bterril@twistedparity.com
'99 M Coupe -
'86 E30 325(e) - Daily Duty
  #18 (permalink)
Old 12-06-2001, 08:53 PM
Matt F's Avatar
Rides:1990 325ic
Matt F is a New Registered Member
I use the good ol' chamois. I usually need 2 passes to get it perfectly dry. Once over to take off the major water, while wringing it out a few times, and then once around again. Nice, no water marks, no lint, easy, cheap.
And the ideal method is to just pour a bucket on slowly to rinse, or just the garden hose with no attachments on the end. I've heard even garden hose sprayers can be bad.
  #19 (permalink)
Old 12-06-2001, 09:46 PM
Rides:'98 M3/4
DSK M3/4 is a New Registered Member
guys, come on, don't ever use an automated car wash!
bond with your car... spend some time with it.
try to find a shady spot to wash the car, it will help stop water marks.
just use a little soap.
use the hose to get off as much dirt as possible.
start from the top and work down. wash out your wash mit or whatever frequently. do the wheels last.
after you are done rinsing, pull the car in the garage to dry it.
use an absorber to dry- much more efficient than a chamois.
wash your wash mit or whatever in the clothes washer before your next car wash.
  #20 (permalink)
Old 12-06-2001, 10:04 PM
kevln's Avatar
Rides:clemato
kevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master Licensekevln has achieved their Master License
looks photochopped...lol
  #21 (permalink)
Old 12-07-2001, 12:55 AM
Rides:95 540i 6-Speed, 02' M3
Dinan540i is a New Registered Member
I use the California Waterblade, I'm not big on the chamois, they piss me off for some reason, just end up cutting them with a big pair of scissors and yelling "who's your daddy!"
  #22 (permalink)
Old 12-07-2001, 01:09 AM
Rides:97 M3
DavidM3 is a New Registered Member
I used one of those DIY car wash things, it left white soap spots all over...never again. Plus, nothing better than taking the time out to wash your car itself.
David -- 97 M3
Custom audio system
front & side clears (rear soon)
aluminum ///M pedals
silver tint
Ellipsoids/HIDs
17" O.Z. Superleggeras
Conforti CAI
Shark Injector
Eventually....
UUC Sways
AA or SS exhaust
AA LTW flywheel
  #23 (permalink)
Old 12-07-2001, 01:18 AM
Yeah, but for those of us at college, it's hard to find your own garage and hose. The DIYs do suck though, that big brush is worthless.
  #24 (permalink)
Old 12-07-2001, 01:26 AM
Utah Rep
Rides:pinto
pressure washers are fine if you only spray then from at least 2 feet away, it doesn't harm the paint from that distance...
cmon guys, its water... sure, if you take a 4000psi pressure washer, and hold it an inch away from the paint, ewll, you'll probably take the paint right off the car, but use a 1000 or so psi unit from a few feet away and its safe... the thing is its pretty pointless...
pressure washers should be saved for cleaning the undercariage and things that are just plain nasty / really greasy... they also do a great job removing large quantities of abrasives without damageing the paint, aka, mud.
  #25 (permalink)
Old 12-07-2001, 04:51 AM
ayton's Avatar
fitter,happier...
Rides:318ti
DIY pressure washers are only as bad as the person using it! like it was said before hold it a few feet away from the car and never touch the paint with that thing! bring chamois to wash the car.
  #26 (permalink)
Old 12-07-2001, 05:45 AM
///M3Ryder NY's Avatar
aka Chris S.
Rides:98 M3
What is an absorber? I've always used either freshly washed towels, or a zymol chamois to dry. Chamois' are annoying though, I find. Towels are good just to lightly drag across and get off excess water, though if that towel aint absolutely soft and clean, you're in for big trouble.
  #27 (permalink)
Old 12-07-2001, 07:09 AM
Rides:E36M3
C///M3 is a New Registered Member
An Absorber is a synthetic chamois... They have many other sythetic chamois out there under different names.
I use the Calif. water blade. Only thing I dont like is that it makes loud streaking noises. I mainly use it on the windows and top surfaces. Then I would use the Absorber to get the harder to reach places.
I dont really like using the pressure washer because its a hassle to clean up. Like they said, just dont spray from an inch away and youll be safe. It works great on dirty rims also.
Those of you who said you wash you car with warm water....
so you get water from inside? seems like a hassle, I just use cold water from the hose.
1995 M3
*Various mods
  #28 (permalink)
Old 12-07-2001, 07:18 AM
aka Chris S.
Rides:98 M3
I have a large wash basin sink in my basement that leads out to the garage and driveway... It has nice warm water. Easier on the hands too in the winter months... Also makes for better suds with whatever car wash you use.
  #29 (permalink)
Old 12-07-2001, 07:57 AM
Rides:1995 540i M-Sport
NoSaabs is a New Registered Member
i detailed cars for a few years, so here are some good tips/tricks that i found. my friends and neighbors are trying to put me in a mental institution because i'm so insane about the cleansliness of my car...
first: warm water is the best. it helps make suds, and breaks down grease and grime more effeciently.
second, if you are washing your car in the sunlight, wash it in pieces. do the hood, bumper and fenders: rinse. roof and doors: rinse. etc... never let soap stay on too long!!!
third: when rinsing, remove the head from the hose and have a nice soft stream of water. don't put your thumb over the end or anything. this actually allows the water to sheet of more evenly and helps prevent spotting.
fourth: the absorber is the best car cleaning tool possible! a great method is to hold it by the top corners, lay it flat on the car and pull down gently. basically remove the water in strips. you'll get streaks if you ball it up. this method will work on the side of the car too because the shammy will stick to the side if it's wet. do this twice on each strip and it'll be perfectly dry with no streaks or spots. note: never never never get any soap on your shammy. it gets absorbed into the shammy's pores and won't come out. it will then leave damaging soap particles on your paint. if you get soap on the shammy, it's ruined! (and i've ruined a few...)
fifth: outside windows. if they aren't too dirty, simply get a barely damp terry cloth (abbrasive is good!) and wipe the windows down. you don't even need windex. as long as some of the cloth is dry it'll be perfectly streakless.
sixth: inside windows: microfiber towels are great. no windex needed and they take streaks right out. $7 for a pack of 5 at Walmart, and they can go in the washing machine! i keep one in my glovebox and it always comes in handy.
ok...i hope that helps yes...i know i'm insane but shouldn't be?
  #30 (permalink)
Old 12-07-2001, 08:08 AM
Banned
Rides:BMW
Re: Ahh.. nothin like the gas station car wash!
Originally posted by ABTS4
http://www.jyoteen.com/mores4photos/m3incarwash.jpg
Ahh... Nothing like an ol' wash at the gas station! Swirl mark hell for that M3!
Nothing like this car wash to put all the other peoples dirt back on your car!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426
