Old 04-29-2002, 12:18 PM
Scho's Avatar
Moderator
Rides:1999 White M3
Cleaner Wax and/or Regular Wax?
When is it necessary to use a cleaner wax? I am about to wax my car this weekend. I was going to wash it first and apply a coat of Meguiars Gold Class car wax. Should I use a cleaner wax first? What the hell does a cleaner wax even do? Should I use a citrus based cleaning agent before applying the wax? I really need help with this! Thanks!
Mike
Old 04-29-2002, 12:43 PM
Quadzilla's Avatar
Panzer Dvsn Racing
Rides:88 E24, 78 E24(GMbH), 3 76 E6, 80 E23(GMbH
Quadzilla is a New Registered Member
Wash and wax time BABY!!!
Step 1. Hose it off
Step 2. Wash with warm soapy water, dish soap is an execelent wax stripper.
If you are just freshening skip to 3a
Step 3. Coupound & polish. Body scrubs work. Clear Coat polishes work too.
Step 3a. Apply cleaner wax & buff out
Step 4. Apply wax coats till it hurts. Thin coats buffed out with microfiber cloths work best.
Step 5. Apply glazing compound.
Step 6. Drive around using the reflection of the road on the hood!!!
Cleaner wax is designed to resurface an exsisting wax layer. It is also used between levels of compound and polish to draw out contaminantes.
Francis Taracido
Panzer Division Racing
Haus der Flugpanzer
(Oo=[][]=oO)
Autobahnpolizeilandstraße Patrouille Verfolgung speziell
Old 04-29-2002, 12:53 PM
Scho's Avatar
Moderator
Rides:1999 White M3
Can you buff the cleaner wax with microfiber towels, or do you need to use a high speed electric buffer???
Old 04-29-2002, 02:43 PM
Scho's Avatar
Moderator
Rides:1999 White M3
Anyone?
Old 04-29-2002, 03:28 PM
E36M3's Avatar
Rides:E36M3 3.3 OBD1, RMS Stg3
E36M3 is a New Registered Member
Cleaner Wax is meant to be applied by hand with a small foam applicator pad. Take the excess wax residue off with a microfiber towel.
Remember that one bottle of cleaner-wax will do your car about 8 times...so don't over-apply. Make sure you apply to a paint surface that is cool to the touch. By the time you are done applying the cleaner-wax to the entire vehicle. go back to where you originally started and begin wiping it off. That should give the product ample time to set up.
Good luck.
Old 04-29-2002, 04:18 PM
Alan's Avatar
Rides:2000 Dinan 740i
Alan is a New Registered Member
OH MY GOD PEOPLE??? CLEANER WAX??? HAVE WE ALL GONE MAD???
Sorry! It's just that cleaner wax is the BIGGEST LIE in the world. Let's take a look at what a cleaner wax is supposed to do...
It is designed to remove LIGHT scratches, LIGHT oxidation, LIGHT residues and LIGHT swrilmarks AND polish and wax your car all in one step. How do you remove these "LIGHT DEFECTS"? With a LIGHT ABRASIVE. What happens as you buff off the dried cleaner wax? You run these light abrasives all over your car and put all the small swirl marks right back into the paint. Think about it, how can something be abrasive AND produce a glass like finishThrow that cleaner wax in the trash, it is about as useful as screendoors on a submarine.
What you REALLY want to do is use a three step system to acheive a perfect finish. I happen to be partial to certain brands so they will be used here as an example.
Step 1: Wash. Wet the whole car down. Use a good carwash soap such as Meguiars Gold Class or Zymol AutoBathe. These are designed to suds away dirt and leave wax on the car. It CAN be useful to use harsher soaps to strip off old wax and start fresh sometimes. Depends on how tires your paint really is. Work one panel at a time never letting the soap dry and using several different rags so as not to drag dirt across the car. Also change the water often. Use a two bucket system so you aren't putting dirt back in the soapy water. When done, wet the whole car again then dry it using an chamois or an absorber.
Step 2: Surface Prep. How bad is your finish? If its just swirl marks and light scratches use 3M Swirl Mark Remover. This is minimally abrasive and will remove small defects in the surface. Once again work one panel at a time and follow the instructions on the bottle. Make sure you get the one for light/dark finishes as appropriate.
If the surface is in very good shape you can also consider using just 3M Imperial Hand Glaze which will "fill in" some very minor scratches and is totally non-abrasive. Also good for working the finish on older rims. 3M IHG can also be used after 3m Swirl Remover to produce and excellent base for your wax.
Step 3: Wax. I use 3M Liquid Show Car Wax. It provides a nice medium between cost, ease of use, depth of shine and durability. As always, use 100% cotton cloths (no nylon stitching) so that you won't add swirls to your de-swirled paint. Work one panel at a time. Don't use too much, a little bit goes a long way. Make sure you cover it all though. If you are messy, mask the balck trim before starting. Wax is a pain to get off trim and sometimes glass. Let it sit for a while. I let mine sit 10 minutes. Buff it off. Buff it again with a clean rag. Next morning lightly mist it with COLD water and buff it again.
I know this seems like a ton of work (it is, last summer I spent a WHOLE day doing this) but the result is very satisfying. Take your time, don't drive at all in between the steps, work in the shade if not a garage. This much work only needs to be done 2-3 times a year for most people. Simple waxes can be done more often. It all depends on how much time you want to spend. Also, I do everything by hand. Machine work can go really fast, but takes a bit of practice and the investment of a GOOD random orbital buffer (~$200), don't just use a power drill.
I will also mention that while this is my ideal process, time constraints have forced me before to use "Do-It-Yourself" car washes with high pressure hoses. I live in the NorthEast so winter beats up my car anyway. As long as I keep it detailed from may through september I'm happy.
Good luck and happy waxing.
Old 04-29-2002, 04:47 PM
Digitalwave's Avatar
loaner
Rides:E30 325i
Digitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master LicenseDigitalwave has achieved their Master License
I don't like cleaner wax at all. Alan posted a very good method... I do it mostly the same except I clay bar after I wash the car with dish soap to strip the old wax. Then I polish with the Meguiars Professional Show Car Glaze. I follow up with one or two (depending on how ambitious I am) coats of the Professional Liquid Yellow Wax. The Meguiars stuff is all right but I want to try some other products like 3M or Zainos when I run out.
Now really, who would want to use ABRASIVES on their paint?
Old 04-29-2002, 05:04 PM
E36M3's Avatar
Unfortunately, some of the above information is incorrect.
A cleaner wax WILL remove hairline imperfections, add gloss and leave a protective layer of wax on your finish in one step.
The reason why the Meguiar's Cleaner Wax (and I am assuming that was the one you were referring to) will not scratch your finish is because the abrasive in that product is called a diminishing abrasive. Simply put, as you work the product in, the abrasive gets smaller and smaller until it is completely gone, removing it's own imperfections.
And FYI...all cleaners are NOT abrasive. Some contain a chemical cleaner instead of an abrasive. The chemical cleaner "softens" the paint to the point where you can finesse it out.
Alan is correct when he says that a 3 step method is best.
Old 04-29-2002, 06:01 PM
Rides:e36
gsE36 is a New Registered Member
I am a believer of clay bar now
My car was so gritty feeling for the past few years (no matter how much i washed and waxed it). My friend raved about clay bar 2 years ago. I finally bought some and gave it a try. Wow, its so smooth right now.
Before my roof and trunk were full of hairline scratches and were so rough. I used the claybar to clear off the residue and dirt and then I waxed it and its great now.
I also like it because its non-abrasive.
To use the clay bar, wash the car, then dilute with some carwashing fluid (maybe 1 oz per 10 litres), and spray it on your car in 2x2 foot sections at a time. Then use the clay bar and gently slide it back and forth on the area that has been sprayed. You'll notice that the claybar picks up impurities in the paint -- little dirt specs, etc). Wash the car after and then wax it and you'll have a nice finish
Old 04-29-2002, 08:29 PM
Alan's Avatar
Claybars are excellent, but at the same time they also remove paint on non-clearcoated finishes. I'm pretty sure up to 1995 all non-metallic finishes from BMW lacked a clear coat. Metallic finishes have them though. I am seriously thinking about doing a clay bar for this springs detail next week...
Digital Wave, try out 3M. Supposedly the show car wax is very similar to Meguair's yellow. The Imperial Hand Glaze is AMAZING though. I still use Meguiars Final Inspection and their Endurance Satin Tire Gel.
But as far as cleaner waxes go, diminishing or not, the idea of wax and abrasive in one step just rubs me the wrong way....(hahaha...ha...h...ok sorry, that was really bad).
Old 04-29-2002, 08:35 PM
mefunny's Avatar
Boost Addict
Rides:e36 m3
mefunny is a New Registered Member
my mom wants to know where can she get those Meguiars if you know where they sell it can you give me the store names?
-Justin
1998 Ford Windstar For sale for $5k
-15% tint all around
-no hub caps(Type R rims look)
Old 04-29-2002, 08:54 PM
fuschnicken's Avatar
][D ][ ][V][ ][D
Rides:Breyton 3
fuschnicken is a New Registered Member
Any auto supply store (i.e. Schucks, Al's Auto, etc.)
TWCompetition Alumni
Old 04-29-2002, 10:26 PM
ToplessBMW3's Avatar
Tony Lukes
Rides:VW
ToplessBMW3 is a New Registered Member
I have used ProGold cleaner wax (it doesn't have much wax at all in it) when detailing cars for the first time. It gets rid of the oxidation, dirt residue, and other impurities in the paint. Yes it is a little abrasive, but how do you expect to remove impurities in the paint without cleaning the surface of the paint?? After that you can use a nice wax (I've always used the classic Mother's in the tin, just pure carnauba wax). The cleaner wax I put on with an orbital that doesn't rotate in a 360 degree motion but kind of vibrates - mimics the motion of your hand putting wax on a car, except at many times the pace. Works wonders, believe me. I've used it on cars and boats and nothing removes oxidation or swirl marks and fine scratches better Also, you can use 3M's Fine Cut if you have a key mark or something deeper; just use a polish after and then wax and then Handglaze. Once you get the paint free of impurities and have a nice thick coat of wax on it as a base, use 3M Imperial Hand Glaze as others have suggested. This stuff is fantastic! Fills in fine swirls and makes the color really shine and gives a great lustre and deepness to it - especially with darker colors such as my Hellrot or black, blue, green, etc. The Clay Bar system also works great to get rid of the dirt that has embedded itself in the paint; I do this every spring after the winter season as the salts and sands from the roads really work their destructive magic on the paint, but the clay bar will take all that right out - highly recommended for paint finishes that are in good shape but just dirty. I use the Hand Glaze about once-twice a month now, keeps the red looking fantastic Good luck everyone,
Sal
Sal
Old 04-30-2002, 07:16 AM
Scho's Avatar
Moderator
Rides:1999 White M3
Thanks everyone for the help! At this time, I don't have any swirl marks that are visible. I am just ready for a good coat or coats of wax. The paint to me is a little dull lately. I just feel I need a good wax job. I was wondering if I should use the cleaner wax. If anyone else has any more input on this situation, it would be greatly appreciated! Thanks all! 5 *'s!
Old 04-30-2002, 11:04 AM
Tony Lukes
Rides:VW
Scho - put a few nice coats of wax on your ride, just make sure it doesn't have any petroleum distillates in it, cause if it does that means it's not really true pure wax and it's not that great for the paint (that's why i use the Mother's in the tin - nothin in there except wax ) After you detail it really good, the next time you wash it, try using the 3M Imperial Hand Glaze. I've never used it on silver, but I'm sure it'll make it look great just like it does on my hellrot Let us know how it comes out. Also, run your hand along the car, and if it feels rough at all or a little gritty, then use the Clay system - you can buy it at Pep Boy's or any detailing place. Then Hand Glaze the whole car and you'll be amazed at what that paint will feel and look like! Good luck man,
Sal
Sal
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
