Old 08-03-2009, 09:41 PM
edo edo is offline
Rides:BMW 528i 2000
edo is a New Registered Member
cleaning rims/alloyes???
usually spend about an hour to clean my car or an hour and a half if im doing both inside and outside and the windows.... which i dont really mind
but
i hate cleaning the alloyes on the 528i 2000 model there are so many spokes and it takes ages....
maybe im not washing them properly or with the wright cloth i dont know but it would take me about 45min to do all 4 of them... is this normal? lol
how do you guys wash em'? do you use washing detergent?
lol such a stupid question... but im interested in how use all do it
Old 08-08-2009, 06:40 AM
Rides:'98 M3 Sedan
fiveightandten is a New Registered Member
Cleaning wheels with a lot of spokes does take a lot of effort and can take a long time.
Cleaning them with regular car wash is fine. I wouldn't use any harsh detergents, and be very careful with using wheels cleaners. I'd only use a high quality wheel cleaner, not a cheap one that's just designed to loosen up wheel funk and will possibly damage the finish on them.
I'd recommend starting over. Take them off the car and give them a good cleaning. Put a few good coats of wax on them (wheel wax if you can procure it). This will be very tedious. But until the wax wears off, it will make cleaning them much easier and less material will adhere to them. Also, some brake dust can be downright corrosive. It gets deposited onto the wheel at high temperatures and can wind up damaging the finish over time if left on there. Keep them waxed up so material is depositing onto the wax, not the wheel.
-Nick
Old 12-09-2009, 12:35 AM
Registered User
Rides:ford,2004
2totoo is a New Registered Member
hi room , after some advise its about alloy wheels they have not been cleaned for over 3 year nor has the car , and no no no its not my rav that gets cleaned ever week it my old escort van . i no its not correct to ask about any other car on a toyota site but , i no people on here have some great tips .. so back to my wheels, like i said i have not cleaned the alloys nor the van in over 3 years and as you can imagine the brake dust it so burnt on now nothing ive tryed will touch them ,, ive tryed wonder wheels , halfords wheel cleaner , and symons wheel cleaner and not one of them has touched them . im thinking of trying brick acid ( 1 part acid 5 parts water ) just not sure if brick acid will affect the tires . any adive on cleaning these alloys would be great other wise its going to be the brick acid , ohh and by the way i aint that bothered if the alloys get a bit knackerd as long as they look clean and dont knacker up my tires .
Old 12-09-2009, 03:15 AM
Registered User
Rides:memo, meny
Jamey Noel is a New Registered Member
Hello guys!
For cleaning the rims and alloyes just use wax polish oil because it will give more shiness and moreover,im using more then six months and getting good result
Old 12-22-2009, 02:47 AM
TOGWT's Avatar
Rides:Audi A8, Jaguar XKE
TOGWT is a New Registered Member
Keeping Wheel Surfaces Clean
It is important to keep wheel surfaces clean, as well as improving the overall look of the vehicle leaving them dirty can have many adverse effects; the black powder coating on the surface of your wheel has four components; a static friction charge (caused by the pads contact with the rotors) that attracts dirt, road tar and other contaminants kicked up by both your vehicle and others. Friction heats the pads and callipers to extremely high temperatures, and causes tiny particles of hot metal to wear off and sent flying in different directions.
Many of these hot metal particles land on your rim and literally fuse themselves to the surface. Finally there is brake pad adhesive, modern brake pads are complex compounds of metals, synthetic materials and adhesives (the binder system) this is designed to wear away under friction like the rest of the pad.
The adhesives used in brake pads can be very difficult to remove and they are also corrosive and will etch the wheel surface, the metal particles from the pads and rotors will become a conduit for rust compromising the paint surface of your wheel
Cleaning Clear Coated Wheels:
• Ensure wheels and rotors are cool before applying cold water as this may cause them to warp.
• Hose off as much initial grime as you can.
• Rinse up into the wheel well to wash away road kill, mud and other debris.
• Use detailing clay and lubrication to remove any embedded contaminants
• Use a d-limonene (citrus) based cleaner to remove any road tar or oil. Apply P21S Total Auto Wash to wheel surfaces and let soak in, agitate with a long-handled boar’s haired brush before rinsing
• Spray P21S Wheel Cleaner (Gel or Liquid) this cleaner is 100% acid-free and will not damage any type of wheel finish. (Gel for badly soiled and regular for normal soil) onto wheel rims and lat soak in (for badly soiled surfaces us P21S-Red (422)
• Used the P21S Polishing Soap on the clean wheel to polish the lips, inner wheel, and face of the wheel. (agitate lightly on the clear coated parts)
• Before finally removing cleaner, agitate with a soft brush and then rinse off (See Wheel Brushes)
• Rinse wheel surface thoroughly with clean water (to avoid splashing paint surface rise by pouring a bucket of water over each wheel from the top down
• Remove any surface imperfections with a suitable clear coat polish (dependent upon extent of damage)
• Dry wheels with a forced air blower; these are extremely powerful and will dry the whole car and the wheels as well. A good tip; flush the rotors and callipers with water until it comes out clear.
• Apply polymer sealant (WheelWax or ZoopSeal) to the surface of the wheels, it will protect the finish from brake dust and the elements and also make them easier to keep clean.
• Organic wax has a low melting point and will not withstand the sustained temperature
Let me know if I can be of further assistance.
An extract from one of a series of unbiased “Detailing Technical Papers” © TOGWT ™ Ltd Copyright 2002-2009, all rights reserved.
Old 01-18-2010, 11:08 AM
beemerteen318i's Avatar
Registered User
Rides:bmw 318i 1985
beemerteen318i is a New Registered Member
thanks.......this really helped
Old 01-19-2010, 04:06 AM
TOGWT's Avatar
Be very careful when using / disposing of Muriatic Acid (its also a form of hydrochloric acid) Muriatic acid has a pH of 0.1 and is used for cleaning cement or bricks
Old 03-14-2010, 12:36 PM
Registered User
Rides:BMW 323 SE 1999
cragglemiester is a New Registered Member
be careful with some wheel cleaners as they contain harsh acids that if left can damage your rims. sealant application helps with future cleaning as brake dust doesnt stick as well and usually comes off with a good pressure wash making the rest simple. - try some billburys if you have tough caked on brake dust.
Old 03-16-2010, 02:24 AM
TOGWT's Avatar
[Cleaning wheels with a lot of spokes does take a lot of effort and can take a long time.]
Spoke & Slot Brush - simple, safe, and effective, ultra-soft bristles squeeze into wheel crevices. Lamb’s Wool Spoke Brush - it replaces those awkward spoke brushes that never seem to be the right size and lack soft bristles on the tip. This tapered ultra soft tool is completely covered with 100% lamb’s wool and is small enough to squeeze between spokes, slots and around bolts 6 1/2" long, 1/2" to 2" in diameter - TOTL
Open for Mothers Day Dinner
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737
