Old 09-17-2004, 07:10 AM
Rides:'90 325ix
SebSter is a New Registered Member
Removing acid rain spots in clearcoat.
Guys my clearcoat has serious acid rain stop damage, ive been reading up that it is removable..but i couldnt find any site with step by step procedures on how i should go about it. Does anybody have any advice on how to do it? Or, shoudl I just leave it up to a detailing place to do it?
Thx.
Seb
Old 09-17-2004, 07:56 AM
BMW Detailer
Rides:325
Region: USA - Great Plains
You will need a buffer, and honestly, more than likely a rotary buffer and some heavy cut compound/polish to remove acid rain etching, but it really depends on the severity of the damage. A picture would certainly help us determine to a better level what would be required. Perhaps a PC would be able to remove the damage, but it is unlikely. Honestly, your best bet is to go over to autopia.org and post up that you need to find a detailer in the Toronto area, there are quite a few weekend enthusiasts that I am sure would be willing to help you for a reasonable amount.
Old 09-17-2004, 09:07 AM
Rides:911 SC 2001
TOGWT is a New Registered Member
Information source: Mike Phillips, Technical Specialist,1-800-854-8073 ext. 189, mphillips@meguiars.com
Quote: Guys my clearcoat has serious acid rain stop damage, ive been reading up that it is removable..but i couldnt find any site with step by step procedures on how i should go about it. Does anybody have any advice on how to do it? Or, shoudl I just leave it up to a detailing place to do it?
I couldn’t find the link so here is the thread-
Only work a small area at a time - about 6 inch by 6 inch area or smaller
Apply using a combination of circular motions and straight-line motions
Work the product against the finish for about 3-4 minutes; it should look as you have almost run out of product.
Re-apply the product and repeat the above steps 2-3 more times
When I apply ScratchX like I have listed above, I am able to get out about 95% of a bird dropping etching or isolated random scratches.
The trick is to work the product in until it just begins to disappear and to apply more than one application. You see, the ScratchX, like all Meguiar's Paint Cleaners, contain a diminishing abrasive, as you work ScratchX in, the microscopic diminishing abrasives gently abrade the surface removing small particles of paint. But as you work it in, these diminishing abrasives breakdown. Thus, they quit abrading the finish and actually polish the finish to a clear, high gloss. This diminishing action turned polishing action is a benefit to you because it enable you to work out defects without leaving scratches behind.
Because the diminishing abrasive breakdown, you need to re-apply and repeat the process until the defects are removed.
Note: You can rarely remove a bird dropping etching, or a scratch, from a clear-coated finish with one application.
"A little technique goes a long way"
ScratchX works, if you work it. It takes a little practice to get the hang of removing defects out of modern clear coats with hi-tech products like ScratchX. It' not like the old days with a traditional lacquer or enamel paint job where you could apply some old-fashioned rubbing compound and in a few passes, the scratch would be gone, (and so would a lot of your paint).
High gloss clear coats are thin delicate surface coatings that are easily dulled and easily scratched. Once they are dulled down and/or scratched, it takes the right product, the right technique together with the human element of care and passion to massage them back to a glistening gemstone.
Have patience, and if at first you don't succeed, try, try again.
Mike
~Hope this helps~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
Old 09-17-2004, 12:28 PM
Rides:'90 325ix
Thanks a lot for the help guys im gonna give it a try. and let you guys know how it goes, if i cant get it out ill post up a pic and give that site a try to find a detailer in the area. Hopefully it will work with the scratch x method though.
(i just noticed a typo in my post, i meant acid rain spot, not stop which makes no sense)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734
