Old 06-01-2004, 08:01 PM
hamann325i's Avatar
SBVT E36 Club Driver
Rides:1996 328i and 1992 325i
hamann325i is a New Registered Member
Detaling Questions!!! Please help!
Hi guys, i have a question. I have some MEguiars Color-X and Some Gold class Car wax, what order should I apply them in, and how many coats each. Also, are there polishes i can put on after I lay down the other coats? Since its getting nicer Out i want a VERY SHINY BMW! Pleasse help. thanks
Old 06-02-2004, 02:54 PM
Rides:1990 BMW 325i
Mark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered Member
the first thing you should do is wash the car, this gets all of the crap off but im sure you knew that. next get a claybar and it will make a smooth surface and remove the shit you cant see. wash it again to get all the residue off. next you want to put a coat of glaze one to fill in some of those swirls and scratches. put on a coat of polish then finish off with a wax. the polish will help deepen the shine and the wax will seal everything up. i did this on my 325i and the results are good. i use meguiars deep crystal wash, wax and polish. get some microfibers too. plan on spending 5-6 hours doing this.
Old 06-02-2004, 03:56 PM
hamann325i's Avatar
thanks for the help man. next sunny day ill do this
Old 06-02-2004, 04:02 PM
Rides:1990 BMW 325i
heres another tip. some people like to use dawn on their first wash, this strips the wax off and leaves you with a fresh base to work with. if you do choose to go this way, make sure you wash the claybar off with regular car wash soap. also if you want a deeper shine then get a buffer.
Old 08-11-2004, 10:40 AM
Rides:911 SC 2001
TOGWT is a New Registered Member
Quote: heres another tip. some people like to use dawn on their first wash, this strips the wax off and leaves you with a fresh base to work with. if you do choose to go this way, make sure you wash the claybar off with regular car wash soap. also if you want a deeper shine then get a buffer.
~ One man’s opinion / observations ~
Sorry man I was with you until the ‘Dawn’ advice.
Washing-up liquids should not be used on vehicles bodywork as their concentrated detergent and usually high sodium / high alkaline detergent soaps content will remove polish / wax and dry out the protective oils from the paint film, rubber and vinyl surfaces, and cause the clear coat to fail.
They will emulsify, breakdown and leach out oils naturally found in your paint, and also any oils you have applied in the way of a polish or glaze. Generally avoid the use of household cleaning products for automotive detailing as they are formulated for an entirely different type of cleaning.
I agree 100% on the buffer though
~ Hope this helps ~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
Old 08-20-2004, 01:51 AM
SpeedRacer
Rides:bmw
bimmerdawg is a New Registered Member
Is it neccessary to re-wash after claying?? I have clayed my car a couple times and there is no residue after the claying. THen again, I took a very long time and did small sections at a time making sure I wiped up the excess lube.
Old 08-22-2004, 08:07 PM
Its all in the wrist
Rides:Pickup
exceldetail is a New Registered Member
My first post but im a detailing fanatic.....As for using a glaze and then polish, bad idea, the polish will remove the glaze and then you have wasted all the effort and product.....You spoke of Gold Class and NXT, both Polymer products, you would be better off doing as Mark said, wash, and then clay. Then use a polish, either the Deep Crystal or Mothers would be ideal, for a maintenance polish. If you have swirls are scratches, you may need something a little more aggressive, like Meg's # 80. Glazes are a good idea, but often are wasted when a consumer user a cleaner/wax. Microfibers are the only way to go, make sure you spend a few $ and buy quality polishing cloths. Take one of those AOL CD's you get in the mail, and after you have purchased a microfiber, rub the towel across the CD several times, if your leaving scratches on the cd, your leaving them on the car too !
Old 08-23-2004, 12:45 AM
SpeedRacer
Rides:bmw
Nice tip with teh CD! What do you mean by consumer cleaner wax?> Are you saying people use a polish/glaze then a wax. But the wax is rubbing off the glaze? What is a good wax after polish or glaze? Meguirs?
Old 08-23-2004, 04:57 AM
Rides:Pickup
Consumer being "user", cleaner/wax being an all in one type of product. MOthers and Meg's both make one, there simple, quick, nearly idiot proof, and marketed/designed for the DYI'er.
If you use a glaze, then a polish, your really reomving the glaze. Glazes are meant to fill hairline scratches. They sort of sit, or lay in the scratch. If you use something aggressive, like polishes are, chances are your just going to "rub it out". Waxes and sealants on the other hand (And im speaking of true wax and sealants, not cleaner/waxes), not being abrasive, will normally flow over, or add additional filling properties to the scratch. You can also use the glaze as you last product for a show, but they have no protective qualities, bvut will make the surface look great !
Old 08-23-2004, 12:47 PM
SpeedRacer
Rides:bmw
Thanks for clarifying! What would you consider Gold Class?
Old 08-23-2004, 06:06 PM
Rides:Pickup
Well, it neither pure Carnauba or Polymer, its a Carnauba/resin product, great initial shine and depth, but lacks durability, good for 4-6 weeks if your lucky. Your really better off going with a polymer product these days, carnaubas just dont hold the flame against polymers anymore.....
Old 09-03-2004, 07:28 AM
P - PLAYER
Rides:E36 325i Coupe FOR SALE!
P-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master License
So, what would a list of meguiar's products that you shall use? (easy to get for me , also that NXT isn't out here yet ) ... and the order it shall be applied for a nice shine?
Is a "polish" a product that cuts the surface back?
A "Wax" to seal/protect the surface?
A "glaze" to fill sctractes?
thanks,
Old 09-03-2004, 08:46 AM
Rides:Pickup
thanks,
Well, not necessarily what i would use, but.....(I carry and use my own products)
IF Megs is readily available to you, go with the following....
Its there 1-2-3 punch. Deep Crystal Cleaner, Deep Crystal Polish, and Carnauba Wax...Its a pretty decent setup for those just beginning or who have limited resources.
Are you using a PC or doing it all by hand ? Makes a difference on product selection and choices!
http://www.exceldetail.com
Old 09-04-2004, 07:00 AM
P - PLAYER
Can't get hold of a PC in Aust (unless i mail order it from USA)... so by hand!
(can i buy another brand of random orbit buffer?)
is the carnauba wax hard to put on? - by hand?
ALSO THE NXT CAME OUT THIS WEEKEND IN AUST! - so that is avaliable to me!
Cheers
Old 09-04-2004, 07:43 AM
Rides:Pickup
Plater, you may be able to find something similiar down under, its worth a shot....The Carnauba is easy by hand, its the taking off that may be difficult. (If you use too much!)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
