  #16 (permalink)
Old 09-05-2004, 04:26 AM
P - PLAYER
Rides:E36 325i Coupe FOR SALE!
P-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master LicenseP-Plater has achieved their Master License
Thanks Excel.... So the carnauba wax is a lot better than Gold Class or NXT?
And also am i right for any of my assumptions below?
Originally Posted by P-Plater
Is a "polish" a product that cuts the surface back?
A "Wax" to seal/protect the surface?
A "glaze" to fill sctractes?
thanks again!
  #17 (permalink)
Old 09-05-2004, 08:35 AM
Its all in the wrist
Rides:Pickup
exceldetail is a New Registered Member
thanks again!
Plater, some suggest that Carnaubas appear richer, but they dont hold a candle to durability vs. polymers. I for one cannot see any appearance advantage going to carnauba. NXT is a Polymer (sealant), Gold Class is Carnauba (wax)......
Polishes remove dead paint, reduce vertical edges on scratches/swirl marks, and rejuvinate oils.
Waxes provide limited protection. Sealants provide what waxes do and more.
Glazes fill very small, fine scratches, but will eventually wash out.
http://www.exceldetail.com
  #18 (permalink)
Old 09-09-2004, 01:00 AM
SpeedRacer
Rides:bmw
bimmerdawg is a New Registered Member
Any recommendations on a good car wash soap? I noticed the Mr. Clean soap contains a polymer in it, but I havent seen any others that say they have that.
  #19 (permalink)
Old 09-09-2004, 06:38 AM
P - PLAYER
Will Polishes add more small scratches untill i use a finer cut (after several layers) this is what i gather when ppl talk about using a PC... but what about by hand!
  #20 (permalink)
Old 09-10-2004, 01:44 AM
SpeedRacer
Rides:bmw
any suggestions?
  #21 (permalink)
Old 09-13-2004, 05:52 PM
SpeedRacer
Rides:bmw
What kind of soap do you guys use? I hear the polymer type is the type that sheets the water off
  #22 (permalink)
Old 09-13-2004, 08:03 PM
Rides:Pickup
Mr Clean soap does have Polymers in it, but after i used it, i noticed a significant decrease in surface slickness, it almost felt like it removed my sealant or wax. I dont know if it was on top of the sealant, or if it did in fact remove it. It did sheet the water off, and no spotting, truthfully iahvent used it since. I aslo noticed a problem with quick detailer products after i used it.
I still feel: good suds (Armor All, NXT wash, Gold Class etc..), good lubricant, sheeting method (Not via Mr Clean), a couple waffle weave drying towels, and some shade, and quick detailing products or Eagle One Wax as U dry, are the best choices....
Bimmer, i still use Armor All Car Wash for all my vehicles, its economical, and works great. Ive heard great things about the NXT wash, and its my belief it has Polymers in it.
  #23 (permalink)
Old 09-13-2004, 08:08 PM
Rides:Pickup
P-Plater, all polishes cause small scratches, its this abrasive action that erases bigger scratches. You just have to be careful in your polish selection. Minor swirls and scratches and you can probably get by with over the counter products, anything above average, i would have other recommendations for you.....Serious scratches involve using heavier grit polishes, or diminishing polishes. You kind of look at it like sanding wood, if you will. If you have something real rough (Heavy swirls/scratches) you go with a heavier grit sandpaper. You take out the bigger scratches, causing smaller scratches. Then you use a medium grit to remove scratches you just put in. You finally work your way to a fine grit, to remove tiny scratches.....Same principle applies to polishing........
  #24 (permalink)
Old 09-13-2004, 11:31 PM
SpeedRacer
Rides:bmw
thanks Excel I will have to check out the armor all Wash or NXT
  #25 (permalink)
Old 09-13-2004, 11:52 PM
P - PLAYER
thanks excel... i understand now...
so would you recomment a complete newbie to detailing to "polish" out my stratches?
  #26 (permalink)
Old 09-14-2004, 05:18 AM
Rides:Pickup
Absolutely, its two fold, shines the surface, and prepares it for better adhesion with a sealant......
  #27 (permalink)
Old 09-14-2004, 05:44 AM
Dewey540i's Avatar
Rides:540/6 97
Perls Shampoo 250 ml (8.5 oz)
Perls Shampoo is an advance in automotive washing. After two years as a best seller in Germany (under the name Raindance Shampoo), Perls is now available in North America! Perls utilizes "Polymolekulare Funktionale" polymer technology.
Application is simple. The rich formula will gently and safely wash the paintwork without stripping wax. As you wash, polymers in Perls bond to the paintwork adding protection from environmental influences and weathering. The proof is in the rinse. Rinse the paintwork of shampoo and notice the formation of tight beading as if you just waxed the paintwork. The results lasts for weeks producing depth and gloss that is unmatched. When combined with the protective properties of our Einszett wax, you'll have the ultimate protection that lasts for up to 6 months.
Superior Detail Supplies
DTM supporting vendor
  #28 (permalink)
Old 09-14-2004, 04:11 PM
SpeedRacer
Rides:bmw
Where Can I find Perls and about how much?
  #29 (permalink)
Old 09-14-2004, 04:29 PM
Dewey540i's Avatar
Rides:540/6 97
It costs around $8 or $9 a bottle. I know Superior Detail Supplies will carry it soon. But for now you should be able to get it at Detailers paradise or Autopia
  #30 (permalink)
Old 09-14-2004, 04:41 PM
Rides:1990 BMW 325i
Mark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered MemberMark_In_PA is a New Registered Member
perls sounds like good stuff, i used to use the zymol autowash, is it a good wash? i really liked it.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308
