| heat gun nice and slow, don't burn the paint!!!
__________________ "driving a formula car is like threading a needle solving a complex math problem all while running on a treadmill for two hours..." Michael Schumacher Yeah, i know i have hardly any posts but i'm still a DTMpower O.G. |
| Hot Hot Water,it'll peal right off, just make sure its warm outside, if the decals on the window.
__________________ ![]() Jonathan Arno Photography Camera: Canon 20D | BG-E2 Vertical Grip Glass: Canon 17-85 f/4-5.6 IS USM | Canon 50 f/1.8 ll | Canon 70-200 f/2.8L IS USM |
| definately a heat gun have done it many times before i used to work at a tint and detail place and i used to remove anything from factory 4x4 stickers from trucks, to stupid flame graphics, and tint with a heat gun. just don't leave the heat gun on the paint too long other wise the heat will burn it use a sweeping motion
| Heat gun (you can heat it only until you can't keep you hand on it for long time), that lift it and peel it. Then you can use goo gone or something else.
| use your fingernail (be careful though it gets hot!!) to peel the corner and continue heating in a back and forth motion over the decal and just pull lightly, chances are you won't have anything left on the paint. if you do i'd use a solvent or rubbing alcohol to remove the adhesive, then clay, then wash and wax the car
| Heat Gun, then peel. Don't even think about touching your car with a razor blade. If you need to get remaining goo from your paint, then go into your house and get some windex. Windex has amonia in it, spray and let sit for about 15 seconds...then wipe with a paper towel.
__________________ BimmerBlogger.com - The Premier BMW Blog |
