Old 04-04-2004, 08:24 PM
Kompressor's Avatar
Go Real Madrid!
Rides:Car.
Kompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered MemberKompressor is a New Registered Member
Have a waxing question...
Long story short I'm waxing a guys car on Tuesday but the thing is he just waxed it a few weeks before. So should I do something to take it off or should I wax it over the original wax or not wax at all.
Thanks.
Old 04-04-2004, 09:00 PM
BMW Detailer
Rides:325
Region: USA - Great Plains
It really makes no difference really. Wax doesn't bond to paint, so really you are just creating a more uniform film build. You can strip it off, but unless you are going to do more than a wash and wax, it really doesn't matter.
Old 04-04-2004, 09:02 PM
Kompressor's Avatar
Go Real Madrid!
Rides:Car.
I'm trying to do a full detail on this car. Do you have any suggestions for anything else to buy like polishes or soemthing? (Not too much money )
Thanks.
Old 04-05-2004, 08:47 AM
BMW Detailer
Rides:325
What's you detailing experience?
Old 04-05-2004, 08:50 PM
Kompressor's Avatar
Go Real Madrid!
Rides:Car.
Not as much as you, that's for damn sure. Not planning on using anything harsh (rotary buffer, wet-sanding, etc.).
Old 04-12-2004, 11:58 AM
lordzeke's Avatar
325is Driver
Rides:93 325is
lordzeke is a New Registered Member
Just throw a nice hand coat on with some good polish and then use some soft cotton terrys or even micro fiber towels and wipe all the wax off. Be sure not to cake any wax into the some seams or cracks, it'll be just more work for you. I've been using Autoglym for a few years now, it's kinda of hard to get hold of, but it's well worth. Once I found this stuff I've never went back to anything else.
Old 04-24-2004, 02:22 PM
dr00t's Avatar
Premium Member
Rides:oscar meyer weiner mobile
dr00t is a New Registered Member
Re: Have a waxing question...
Thanks.
YES!
I am surprised nobody caught this earlier.
If the car has an existing layer of wax, you need to wash the car using DAWN soap. Dawn soap is unlike any other soap. It is essentially "ANTI-Wax". Once you have washed the entire car in Dawn soap, you can then start doing your thing. BUT, just make sure if you do use Dawn soap..you NEED to re-wax in the same-day. Make sure and tell the car's owner NOT to wash his car with anything except a specific "Car Wash Soap" after that. I recommend a reddish/purple jug of McGuires Car Wash Soap that can easily be purchased at any Auto Zone.
If you have more specific questions about the process of a full detail, feel free to ask.
-Dan
Old 04-25-2004, 08:07 AM
BMW Detailer
Rides:325
Why does he need to remove the wax? Its not hurting anything and you can't get a measurable film build from wax, you simple add a more uniform density of wax. Also, Dawn is extremely harsh on rubber trim. The only reason Dawn was ever recommended for a wash is by Zaino which requires an oil free surface prior to Zainoing because of the chemical bonds formed. Wax doesn't bond to paint, hence the reason one can use a glaze prior to waxing. If you are really worried about prior wax being there, use a 50/50 mixtures of isopropanol/water, it will remove the oils from the surface that might inhibit bonding of a sealant.
Dawn is for dishes. Don't use it for cars.
Old 04-25-2004, 02:08 PM
dr00t's Avatar
Premium Member
Greg, I'm sorry, but you're wrong.
Dawn repells wax.
I asked this question on the Autopia forums assuming you might see it, but I guess you did not. But a simple answer to your theory would be as follows:
Joe from Autopia writes:
If you wax the car, then wash it with dawn, you won't have wax on the car anymore. Usually you want to dawn the car before you begin detailing so if you polish, you know you're polishing the paint surface rather than having to cut through the existing wax first.
Initially, I personally found it hard to believe. Once I decided to test this Dawn idea, it became apparent. The workload is much easier and you can produce a more "Perfect Shine".
BimmerBlogger.com - The Premier BMW Blog
Old 04-25-2004, 04:34 PM
BMW Detailer
Rides:325
Trust me man, I know what Dawn does for cars. If you are polishing, the microscopic layer of wax will be removed instantly. Wax is not hard to take off of paint. There is no "cutting through exisiting wax." Claying will remove wax, 3 car washes will remove a layer of wax, the second you hit the paint with any kind of polish/cleaner/compound, the wax is gone and the wax most certainly does not interfere with the polish doing its job. Dawn is nothing more than a strong/harsh detergent. Like I said, if you feel the need to remove the wax for whatever reason, just hit it with some isopropanol alcohol/water mixture.
Old 04-26-2004, 12:29 AM
dr00t's Avatar
Premium Member
... I guess this is just a case of having more than one way of doing something.
Old 04-26-2004, 08:48 PM
lordzeke's Avatar
325is Driver
Rides:93 325is
Greg is right, there really is no need to "take off" the wax. You start telling people to use dish soap, I hope none you use guys use any lemon or orange stuff. Stay away from that crap, it will do some damage, I guess the "acid like" cleasning eats right into your paint. Besides after a few weeks to a month and some washes the wax will start to break down on it's own. And about the clay, that stuff is awesome, it takes more work but it's well worth it espeacially for you guys that park your cars outside. Like Me!
And when you clay your paint make sure your car stays wet, don't let dry or spot up too much. When we clay cars also a few drops of soap for each panel and buff all those spots of your paint. Dry it real good then use your favorite wax. We use this process for every car and it never fails to leave a fantastic shine.
And for guys that can handle a high speed buffer, will get even BETTER results!!
Old 04-29-2004, 12:17 AM
dr00t's Avatar
Premium Member
Well, I guess my DAWN soaping knowledge was wrong coming from Autopia.org (The most expert detailing forum on the net) and my 5 years of detailing cars with one of the largest client bases in Indianapolis (No complaints yet).
Anyhow, as I stated, I think its just one of those things that distinguish a professional detailer from an amature.
In regards to the clay bar water spots. I agree, you should always lubricate the area you are claying and wipe with a microfiber towel as soon as possible, BUT...
If you are claying your car, you should NOT be going directly to wax after clay. You should be polishing, THEN, waxing.
I recommend you read the book by David Bynon about "The Perfect Shine". It gives explanations for all of these reasons.
Fortunately, it is free now. I paid 15 bucks for it back in the day.
http://autopia-carcare.com/freeguide.html
Hope this helps you in your detailing endeavors.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
