Old 07-01-2003, 07:34 AM
///Mummmmm's Avatar
Entrepreneur
Rides:E36
///Mummmmm is a New Registered Member
Exclamation How to detail a Car, Once and for all!
Everyone seems to have questions about how to clean their car properly, and quite frankly there are several correct ways. But having been a detailer for over a year I’ve finally acquired enough information to do a decent write up on how it should be done.
You should always begin by cleaning you’re front windshield, side glass, and rear glass (with water and soap) to remove any dirt or bugs that may have built up. I do it in this order so I can then apply Rain-X Original Glass Treatment and Cleaner (Rain-X) I do it before I wash the car because if you don’t, if you’ve ever used Rain-X before you’ll notice that it leaves streaks if you use it last. By doing it in this order you remove the streaks when you wash the car.
The next step is to wet the car thoroughly; I’ve seen so many people have terrible scratches because the just start washing their car without wetting if down first. Now you will spray some sort of tire cleaner on your tires, I recommend http://meguiars.dailyshopper.com/ind...iqueid=1049619 which is a decent wheel cleaner that breaks down break dust and allows easy cleaning. (It’s not quite what the pro’s use, but it’s close enough.) A hint about rim/tire cleaning, just do one at a time. If some tire cleaner solutions sit on nice rims for more than 5-10 minutes they begin to eat the clear coat.
You will then mix a bucket of soap https://www.duragloss.com/new/index2.html (NO. 901/903 CAR WASH) It suds very well, and has several active ingredients that help break up dirt. I always mix my soap a little richer than what the directions call for. A bottle out the red stuff (on the link) usually lasts about 1 year) I also recommend that you mix your soap with WARM water. It helps the soap sud more. I begin washing at the top of the car, leaving any areas below the door moldings for last, as this area seems to collect the most dirt. Last I will clean the rocker panels, and hit behind the tires (fender wells) as best I can. You may also want to go ahead and hit the engine bay while you’re at it. (I often repeat the entire process to make sure I get every spot clean)
The next step would be to dry the car. Now, I worked at Porsche for over a year, every day we washed and dried $120,000 996-twin turbo’s with the California water blade. They DO NOT scratch cars. I know we have washed over 10,000 cars and never had a scratch come from a water blade. However you want to make sure that the lip of the blade is free of any dirt before you begin the drying process. The blade doesn’t go into every single nook and cranny, so I often use a shammy or an absorber to remove the excess water.
Now that the car is dry. If you wish to apply wax, let the car sit in a cool area for about an hour before application. It just helps the wax go on easier. Now I prefer to use Meguiars Cleaner/Wax first, going over anything on the car above the moldings. I then allow this to dry for about 20 minutes, before I use a 3M Yellow Detailing cloth to remove the wax. Then I apply another coat of Meguiars Carnauba wax to protect the surface, let it sit for 20 minutes, and remove the 2nd coat.
I then begin on the interior of the car. It’s always best to use a air compressor in conjunction with a good strong vacuum. Begin by removing all the floor carpet. Then blow out the seats with the air compressor, you will then want to vacuum the floors, and if there are stains present, make a mixture of water and wheel cleaner, and spray them on the stained area. ½ water ½ wheel cleaner works great to remove stains. Next I would the lexol cleaning process on my seats and dash, it’s pretty simple, just go out and buy the lexol leather cleaner, and then apply the cream. You may now want to clean the interior windows with Windex (or soap and water if you have tint.) and you should be set to go. If you have any other questions ask, and I will attempt to answer.
Oh yeah, if you want a nice (clean smell) try Freebreez (sp) Deep Clean. It works great!!!
Old 07-01-2003, 10:47 AM
BMW Detailer
Rides:325
Region: USA - Great Plains
Honestly dude, I would not let you touch my car after this write up. Most of the stuff you said is ok, not a big fan of Megs. wheel cleaner- too harsh and acidic. Second- wheel cleaner on the carpets- not on my car and I hope not on any that you detail. Windex is a terrible automotive glass cleaner, I would think anyone that has been in the detailing business for over a year now would have realized that Windex is not made for automotive glass. Also, you make no mention of the type of towels you are using, but I am going to make a lofty assumption that you use high quality microfiber towels. Now you've just TOTALLY NEGLECTED any type of paint prep work at all. Maybe clay the car? Here's a novelty- machine polish to remove swirls, scratches, imperfections. A professional detailer is someone who can provide a service that your typical person can't do themselves. I.E. machine polishing, steam cleaning, and so on. BASICALLY YOU'VE TAKEN A PAGE TO EXPLAIN HOW TO WASH AND WAX A CAR. That is fine, but I sure hope people don't actually pay you to perform this DIFFICULT service.
Like I said before, I would not let you touch my car because frankly you just exhibited that you know nothing about detailing and I hope no one takes any of this advice to heart because this is not how to properly detail a car.
Old 07-01-2003, 11:30 AM
///M3Ryder NY's Avatar
aka Chris S.
Rides:98 M3
I kinda have to concur with Greg here. Maybe you just did a real quick and dirty write-up (no pun intended), but your steps are certainly missing some critical items and points. The most glaring to me was also the lack of mention of towels, ie. microfibers. To say that a CWB NEVER scratches a car's surface is pure bull$hit. One tiny spec of dirt remaining on the car, and you will put a scratch with that thing. Drying is much more effectively and safely done with a steady stream of water, allowing it to sheet off, then the remaining water blotted with a nice soft MF waffle weave.
You talk primarily about washing techniques, but nowhere in there do you make mention of using two buckets, one for soap, and one for rinsing. Furthermore, I'm assuming you use the same wash mitt on the lower panels of your car, as for the uppers, since you didn't say otherwise.... Big nono. i use one mitt for the hood, roof, trunk and sides. Another mitt for bumpers and below the moldings.....and an entirely different mitt and bucket for rims.
I think your intent was good, but you missed some critical pointers....
Old 07-10-2003, 03:27 PM
andyman's Avatar
Traitor
Rides:W210 E55 AMG
andyman is a New Registered Member
no doubt fo shizzle.an air compressor set at low psi is awsome as well to help dry the car in the nooks and crannies(like water dripping from moldings,lights,sideview mirrors,etc...)before waxing.actually,it just blows the water out of there,then i have to dry it with an absorber.works good tho.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
