| check to see if there are any burn marks on th plugs....sometimes if a "hot wire" touches a ground it will spark...what i usually do to clean it is by using an eraser...they work fine...u just have to make sure u get all the eraser stuff out if it falls in the lil cracks of the plugs....also if u can try opening ur deck and see if the button is cracked or broken...if it is broken that is probally why u have to push it in more in order for it to work....sorry i cant tell u how to take out the tape deck since i never had the stock one....i dont think it should be so hard...try taking out the ac switch by pulling off the 2 front nobs and then then taking out the screws....after that the switch should push right in. after ur done with that try to push the deck out from underneath....thats all i can think of...if u have any more questions just ask -Anh
