Old 12-15-2001, 10:40 PM
Rides:HELLROT '95 325i
Red Bimmer is a New Registered Member
My speakers are whining when I accelerate, help
I've heard people say using the stock amp w/ a aftermarket headunit will F__k it up, but I also heard this was Bull. BUt recently the sound has been deteriorating and last week the speakers have begun to whine when i accelerate. I have a (sony xplod) headunit, the sound actually imporved when i installed it at first, but not anymore. What can i do, if anything. Thanks
Old 12-16-2001, 09:46 PM
Rides:1990 Volvo 740 Turbo
LBKornhusker is a New Registered Member
Well, your first problem is having a Sony headunit...
Was it professionally installed or a DIY job? Also, are you running stock plug wires? If interference is being caused by the electricity from the ignition system, some higher quality wires (MSD or Magnecor) may prevent this interference from messing with the audio system. Good luck.
Honda-Acura.net Engine Tech Forum Moderator
Honda-Acura.net CR-V Forum Moderator
Off-topic.net Hybrid Forum Moderator
Old 12-17-2001, 10:08 AM
Rides:1995 Avus Blue M3
M3StateGuy is a New Registered Member
I used to have this problem in my 318i...I had to search the whole wiring system and shift wires around so that they were not touching any others. This was the biggest b**ch to do, it took me hours to sort everything out and find which wires were the problem. Not only are ignitions wires the problem, but any wireds that carry power from the battery. My problem ended up being a speaker wire that was too close to a powerwire underneath the trim. Good luck on finding the problem.
______________________
1995 Avus Blue
Intake
Light Mirror tint
PIAA superwhites
H7 Superfogs
Clear turnsignals and markers
Blacked out Grills
Kenwood CD player
12w6 JL sub rockford amp
39,000 miles
Favorite Quote "Happieness is not just around the corner, happieness IS the corner"
Old 12-17-2001, 11:00 AM
YA I kninda didnt like the Sony at first but then again it's red and plays MP3 (for 300bucks), anyway, even if there is a wire touching can this cause any harm. Because it was a "proffesional" install, but all they did was attach the adapter and anetenna, not other wires were changed or tampered with. And im not too confortable w/ messing with the iginition wires cause it was EWS. THanks
Old 12-17-2001, 01:52 PM
Originally posted by Red Bimmer
YA I kninda didnt like the Sony at first but then again it's red...
Well, if it's RED...
Old 12-17-2001, 02:02 PM
Rides:95 M3
Mike///M is a New Registered Member
Exclamation
I think you may have a ground loop
-Mike 95 M3
Old 12-17-2001, 07:51 PM
Joe Joe is offline
Rides:BMW M3 Sedan 1998
Joe is a New Registered Member
I ended up having my wiring harness connector too close to my antenna wire and RCA's. Take out your stereo. Look back there at the connections for your antenna, your RCA's and your factory wiring harness. I did the following: Tuck the fat-ass wiring-harness-connector behind the piece of plastic that the rear of the factory headunit rested on. Take your RCA's and move them to one side, and move your antenna wires to another side. Slowly tuck in your stereo until it clicks, and pray that it's all good.
If you're using the stock amp and stock wiring to your speakers, you really shouldn't have a ground loop problem. Check your speaker connections, and do what I said above in the dash... ..you should be alright.
Old 12-18-2001, 08:30 AM
THanks, IM going to try that tommorrow.
Old 12-21-2001, 03:39 AM
Rides:BMW,330i, 2001
SSD STYLE is a New Registered Member
Exclamation whinning noise
make sure to check the crossovers aren't to close to the wires going to your battery. The interference for the ground wires could be causing the whine.
Old 12-21-2001, 10:11 PM
I tried it and still it whines. I just remembered removing the rear seat (where the air bad sensor is revealed) and replaceing it, are there any speaker or culprit wires going under the rear seat? thanks And where exactly would the crossovers be, excuse my ignorance i dont know what crossovers are (i think they separate bass and treble right)?
Old 12-27-2001, 01:33 PM
Deejay Falco's Avatar
Rides:'99 E36 M3
Deejay Falco is a New Registered Member
I know EXACTLY what it is. I hate that shit. As you rev does the pitch of the whining get higher, and when you drop the clutch to change gears it goes away and comes back when you put the new gear in?
Its the sound of you batteries through a pair of your speakers.
To see which speakers they are stop the car with the sound pretty loud and go to each speaker put your ear to it and find out which speaker(s) it is you cant hear out of. Most likely it will be two speakers that are on the same channel on your amp.
The reason you get the whinning sound is because you are losing "signal" or good "reception" for lack of a better word -- your RCAs have to be in a perfect position for the speakers not to faulter ... its like you have the connection hanging by a thread.
Solution #1-- push them together REALLY hard until you can physically hear the other speakers "turn on" -- yes, turn on, the speakers are connected and powered but there is no audio coming from them beacuse you are hearing the batteries noise instead due to the weak "signal/reception" between the RCAs -- then tape it down with electrical tape very tightly so it doesnt move from that position.
Solution #2--get MONSTOR cables or expensive RCAs from RADIO SHACK--just ask them for the best RCAs they have that prevent them from losing "signal/reception."
You may have to rewire it all the way to the front of the car if it is connected to the battery, or you may only have to change the splitter if you're using one. In my case i had to change both, but because I was too lazy to rewire it to the front of the car at first, I used the tape method and it worked pretty well.
If you need more explaination on how to do it let me know PM me or E-Mail me.
Good luck!
John
Old 12-27-2001, 02:06 PM
Yup you described it exactly, as I rev the whine's pitch gets louder. As to the solution, is this what I should do? I should have someone rev the car while I try to hear where the whineing is coming from (whcih speaker) and then ISolate that speaker by taking the speaker wires and wrapping electrical tape around it right. Im not really into rewiring the whole car cause IM planning on getting an m3 and would not want to spend the $$$ on a system for this e36.
I dont even want to buy an amp (might need a component sys for the m3) but I do have a 10in sub. So I removed both speakers in the rear deck, seperated the wires from the adapter (4wires, 2for tweeter and 2 for the speaker for bass). I used the wires from both the left and right side from the supposed speaker for bass and joind them going into the subwoofer which is in a box. I revomned the twetters from the 4t box and fastened them to the speaker grill free dangling. So, I have the opening for the bass sound to come into the cabin and the tweeters. I think this might be my problem. I was just wondering if this would be causing any harm to my car in general. Thanks
Old 12-30-2001, 09:01 AM
Rides:1996 328isA
JimBob is a New Registered Member
Question Same Prob here...
I have a completely stock system with the CD changer in the back -where the heck do I even start to look for a problem? And why would it would it just start up now? Too wierd.
Is stock really so bad?
Old 01-12-2002, 09:53 AM
Rides:1992 325i
DiscoStu is a New Registered Member
I had the same problem, none of the solution proposed worked. I had $100 Monster cables, ground loop isolators and some really high end stuff; stil had noise. It turned ou that I had the input sensitivity turned up way too much on my amps.
Give it a try.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547
