Old 02-26-2003, 04:59 PM
I smoke only dro
Rides:1997 M3
BlueIce is a New Registered Member
Thumbs down Squeaking and vibrating of rear deck against rear windshield w/ sub hits!?
Ive pretty much got a lot of the other rattling under control in the trunk, but the rear deck I cant seem to stop from making tons of noise when the rear seats are folded up. I already stuffed the bottom of it with t-shirts to stop it from vibrating up and down, making that loud banging noise. That still didnt stop it from vibrating against the rear windshield and making another noise, plus some kind of squeaking noise whenever the bass hits. I tried putting paper towels in the crack between the glass and the rear deck around the hump for the 3rd brakelight and about 6 inches to either side of the hump, and the sounds didnt really change. What can I do to remedy this? Its making the bass sound really shitty!
1994 325i Jet Black / Black --RIP--
Old 05-22-2003, 08:25 AM
BMW318isT's Avatar
Batwing member
Rides:BMW 325is 1995
BMW318isT is a New Registered Member
Your problem... my problem
I have the same problem with my E36... I'm guessing your runnin a lot of power. My approach is going to first make sure that the center air vent cover is solid, by making a rubber seal for it. Then I am going to put rubber strips between the rear deck cover and windsheild. If that doesn't work, I will probably cut a sizable port in the rear deck as the decrease the pressure in the trunk and increase sound in the cabin. If all else fails, I may try, bear with me, Dynamat (which is extremely overpriced). I will tell you how it goes.
- Mike - 12/94 1995 325is
Exterior: Ivory White 1995 BMW 325is, 18" Triple Plated Chrome M3 Wheels, Fiber Front Bumper/Splitter
Racing Dynamics Rear Wing, Eibach Lowering Springs, Bilstein Sport Shocks, Projector Headlights with Halo's
Kamei Eyelids, Kuhmo MX 225/40-ZR18, BMW Factory Alarm & Stellar RTX Alarm, OPTX Red Underglow
Engine: M3 Exhaust, M3 Transmission with custom (harmonically balanced)driveshaft, UUC Short Shift Kit,
BMW Advanced Traction Control System
Interior Mods: Full fiberglass trunk sub install, M3 Vader leather heated seats, Kenwood KDC-X789 Head Unit mp3 with G-Meter, Pioneer DVH-5000MP DVD Player, Savv Mirror LCD Screen, NESA 7" Widecreen Monitor, Zender (German) Aluminum Pedal Kit and E-Brake, Polk Momo 500.1 Sub Amplifier,2 MB Quart PWE-352 15" Subs, MB Quart 5 1/4" all around, JL 500/5 amp
Old 05-22-2003, 08:27 AM
BMW318isT's Avatar
Batwing member
ha
by the way, my system now has a JL 500 on it... and i sold all the cheap stuff. I have one chrome Audiobahn 15 Flame Q sub.
Old 05-22-2003, 01:42 PM
belgian love
Rides:1994 318i
Region: USA - Rocky Mountains
hmm yeah i have the same problem, and i tried the old "stuff it full of cloth" trick to no avail. I pulled off the deck and I re-glued the stock dampening material, and im going to get some spray on dampening and put on a bunch of coats. if that doesnt work, then ill try sealing over the holes.
Old 05-24-2003, 06:50 PM
belgian love
Rides:1994 318i
ok, ive figured it out guys, to get rid of that annoying rear deck vibration problem, cover up the holes to the trunk.
This weekend i just got really pissed about it, and decided to take it out and see what i could do. I tried the cotton stuffing trick. didnt work. so i practically took the entire back half of my car apart. I pulled off the rear deck and noticed some stock dampening material and reglued it with silicon glue. then after this i went to problem solving.
The vents underneath the rear deck are the problem. So... I had some steel sheet metal (pretty stiff, but bendable with pliers) lying around and decided to cut out some pieces to fit over the holes. I had metal cutting scissors (courtesy of lowe's for $15) and measured and cut. Then, to get a flush seal, I bent a little bit of the bottom to make a lip and same with the top. then i put two holes in each piece, and got some bolts and made a metal piece for the otherside to clamp down on. between each piece, I put some thin carpet to dampen it in case it decided to rattle. tighten it down, and viola. PS youll need an extra set of hands to hold the top piece while youre tightening underneath.
It works like a charm. Now i can only feel the vibrations, but no rattling.
Old 05-24-2003, 09:38 PM
Scarface's Avatar
BuchhbrunnM3 on bfc
Rides:'95 M3, '98 540i6, '02 Escalade
Scarface is a New Registered Member
dynamat way overpriced? puuuhhhleeeeaassseee! Have you ever used the stuff before? The stuff works exceptionally well every time I have used it, it serves its purpose and does the job when used right..In your case though you seemed to come out good. We had a customer a while back who had a 57 Studebaker who complained of alot of road noise and his trunk rattled some from his small system he had. Well, we ended up talking him into a $1200 dynamat sale(including labor) and we did the WHOLE car, and when i say whole i mean the whole thing...Every square inch possible of bare metal in the trunk, the interior which was stripped out, doors, firewall, under the hood and when we were done he was thrilled. Not only did it make a huge difference in his road noise, but it enhanced the sound of his music so much it sounded like a different system when done. Now I'm not saying go out and spend 1200 like he did, but to fix your problem had what you done not fixed it, a simple wedge pack would have fixed the problem and cost approx 25-30(retail), and you probably would have had some left to use somewhere else...
Old 05-25-2003, 08:15 PM
belgian love
Rides:1994 318i
yes, well some of us arent quite as rich as the others out there.
but i agree with you, dynamat is nice, but the spray ons are nicer i believe. it gets into all the nooks and crannies, and if you know how to use it, getting into the nooks an crannies is a good thing
Old 05-25-2003, 09:41 PM
Scarface's Avatar
BuchhbrunnM3 on bfc
yeah i agree with you on the spray on application, that stuff does get up in corners, nooks and crannies well!
Old 05-25-2003, 10:53 PM
///BimmerPower's Avatar
Rides:3.5l Turbo Diesel, zx10r, e36 325, 05 SRT-4
///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License
Good to hear that you solved the rattling problem. My 1200watt 15" Solobaric is annoying the shit out of me too and i def wanna do something about it now that i have some time on my hands. Is it possibble to take some pictures of what you did so that we can get a clearer idea of what you did? Can't wait till i hear only the sub and not the rear deck vibs .
Bayerische Motoren Werke
Old 05-26-2003, 07:35 AM
Scarface's Avatar
BuchhbrunnM3 on bfc
ahhh solobaric, thats a very good sub that i sell the hell out of!! We have 2 of the new 18 inch solo x's sitting in the showroom waiting to go into a car..I can't wait to hear them!
Old 05-26-2003, 08:38 AM
Rides:BMW 325is '92
Chinaboi is a New Registered Member
any pics on how you solved your rattling problem?
http://www.dtmpower.net/forum/attachment.php?s=&postid=653194
M3 Exhuast
M3 Spoiler
Rieger Infinity Lip Spoiler
Mattig Lids
Eibach Pro-Kit
Bilstein Shocks
17" ACE Monoco
Euro Clears
ZKW Ellipsoids with SPP Angel Eyes
Stage II 5000K Osram Xenons
Updated grill
Sony Head Unit, Rockford Amps
Old 05-26-2003, 08:37 PM
belgian love
Rides:1994 318i
ill try and get pics up as soon as i can.
but tell me.... how do i post pictures? how do i put them in my album? anyway to post them without a website?
Old 05-31-2003, 09:43 PM
cbouchez's Avatar
AC SCHNITZER
Rides:92 325I,2001 540IT, E30 325is, MKII GLI
cbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master License
yeah post some pics man, thanks!
Old 07-11-2003, 01:29 AM
Midnight Shark's Avatar
Will work for food
Rides:'02 Double DD, bye-bye M3 :(
Midnight Shark is a New Registered Member
I know this thread is old but......
WHERE'S THE PICS?
Old 07-11-2003, 02:15 PM
Word... I'm having serious vibrating problems... you still got them pics hiding on your computer?? Later
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287
