Old 12-30-2002, 10:57 AM
E46_328Ci's Avatar
Certified Gangsta
Rides:S14
E46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master LicenseE46_328Ci has achieved their Master License
When Capturing Video+Audio.....
Its all choppy!!! why is that?
sorry i'm a newbie at this video editing stuff.... i can't seem to figure out why!
Edit:
I have a P4 1.5 and 512mb so i should be straight. what the deal !
Old 01-01-2003, 06:09 AM
BIG PIMP
Rides:2006 Nissan Titan
silver323 is a New Registered Member
is it choppy when played back on the computer ? also what kind of camera? are you using usb or firewire ? need more info, what software are you using to capture, and what settings within the software are you using when capturing ?
Old 01-01-2003, 09:16 AM
Rides:BMW, Z3 3.0, 2001
bdougr is a New Registered Member
also try to down sample the audio. even go MONO unless it is important to have high definition
Old 01-01-2003, 09:52 AM
E46_328Ci's Avatar
Certified Gangsta
Rides:S14
oh shit, sorry about the LACK OF INFOMATION!!
Panasonic pv-dc252 - Cam
Adaptec Fireconnect 4300 - 1394 card
Computer:
P4 1.5
512mbSD
GeForce4 4400Ti 128ddr
http://mason.gmu.edu/~hdo/hookedup.00.avi
there is my first video... choppy as hell!! used Adobe Premier to do all the Capturing and whatnot.
I used VirtualDub to compress the audio and video using DivX and 32kb sound.
what can i do to fix it
my capture settings.... lemme peep it out right fast,
Video:
Compressor: Microsoft DV (NTSC)
Frame Size: 720x480
Frame Rate: 29.97fps
Depth: Millionssssss
Quality: 100%
Audio
Rate: 32000hz
Audio: 16bit Stereo
edit:
try not to hammer my school's webserver... lol!!
Old 01-01-2003, 03:33 PM
BIG PIMP
hmmm..... hard to say what that is caused from, does it play fine in adobe after capturing it ? and also, just use adobe to compress the file, go to file and explor timeline, and click on advanced, something about explort for web or something, im not on my computer with adobe right now, it does a good job. check out my movie at http://WWW2.NETDOOR.COM/~RAYP , right click it and save, it's at the bottom of the page there, all done with adobe.
Old 01-01-2003, 04:41 PM
E46_328Ci's Avatar
Certified Gangsta
Rides:S14
no it doesn't play fine in adobe... its even choppy when im capturing.
Old 01-01-2003, 05:08 PM
Castro's Avatar
CF Rieger 'Vert
Rides:BMW
Castro is a New Registered Member
Does it play like that on the tape? Trying to capture it without any skipped frames thats what causes the choppyness. If it always skips frames then the source (your tape) is bad or your computer can't handel the information but i doubt its the computer.
Hope that helps
Old 01-01-2003, 06:25 PM
E46_328Ci's Avatar
Certified Gangsta
Rides:S14
it might be my computer? I don't know but i can't figure it out!!! ahhhhh
Old 01-01-2003, 06:27 PM
Honda Whore
Rides:Honda S2000
mooboydc5 is a New Registered Member
I would check for programs running in the background like adware... It should at least play smoothly before you export...
Old 01-01-2003, 08:31 PM
BIG PIMP
make sure you have all other programs closed that would cause lagging. if you have windows xp, go to start , run, type in msconfig and click ok, then put the computer in selective startup, and then click the start up tab, then click disable all, but go back and reselect any antivirus software that you may want to run, you probably just have too many programs running and lagging the system , either this or you are using the wrong settings when capturing...
Old 01-01-2003, 09:40 PM
E46_328Ci's Avatar
Certified Gangsta
Rides:S14
surprisingly, I only have 4 things on my startup... nothing really laggy that loads up, i went ahead and disabled those, i ran a ad-ware program so it deleted a lot of that Ad-Crap.
Running Anti-Virus now, and going to defrag tonight and capture hopefully something nice tomorrow!
Old 01-04-2003, 10:09 PM
E46_328Ci's Avatar
Certified Gangsta
Rides:S14
anyone? i can't seem to figure out why!!!
Old 01-04-2003, 10:38 PM
AdrenalineRace's Avatar
To be
Rides:Tailgater
AdrenalineRace is a New Registered Member
Normally logging problems are caused by having other programs running at the same time. You chose all of the right options, and you computer is more than fast enough to capture video correctly. It may be a bad firewire. Take it to someone else's computer and see if it works on their's.
Old 01-05-2003, 05:26 PM
White Gt's Avatar
Rides:Your car
White Gt is a New Registered Member
I got this problem with my old 10.2 GIGS ATA 66 hard drive and solved it with my new ATA 133 80GIGS with (PCI SCSI adaptor Card) because my main board hard drive controller is just ATA 66.
And i only got this problem on Adobe not with MGi Videowave III or videostudio. The weird thing is that you got a fast computer and you're not supposed to get this problem.
Here's my advice:
Trying MGI V...... just to see if the problem is with others capture program.
Trying to use another PCI slot for your firewire card maybe it's a conflict with another card.
my 0.02$
" The eye sees only what the mind is prepared to comprehend "
« Henri Bergson »
Old 01-05-2003, 06:09 PM
Scho's Avatar
Moderator
Rides:1999 White M3
Mine sometimes looks choppy when uploading from the firewire, but it plays and edits fine. If your camera is connected, it should look fine on the screen of the camera. That is what I go by. I am getting another monitor for playback as well when editing.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
