Old 05-27-2002, 10:48 AM
Rides:silver 323i 2000
Beemah702 is a New Registered Member
Custom Trunk Audio Problem
i am a big fan of customs trunk setups, but i have a problem. i bought my 323i wid the non foldable rear seats, and i found out that my trunk ish all metal (wall to wall). One day i decided to put my friends two 10inch subs in my trunk to see how it would sound. to my surprise it sounded ****ty. i only heard and felt vibration, no boom boom. from this i am scared to get a custom setup and afraid that it might sound the same as the time i put my homies subz in my car. i was told to make a hole where the arm rest folds down in the rear and it should sound better, and i should get a bandpass setup wid one 12inch sub. how does this sound? Any input on my situation and what should i do?
Dunt you love it when sumone turns there head to look at yur car? HAHA!!!!
Old 05-27-2002, 11:29 AM
BEHMER's Avatar
Rides:Tangible Dream
BEHMER is a New Registered Member
You could always cut out a few ports in your rear deck. Thats what I did in my E36 then used OEM speker grills to cover up the choped up metal My seats fold down too for some good beats Check the pic...
-Custom Widebody 332i-
-Custom HRE wheels-
-Focal Audio:-
Alpine PXA-H701+C701-
-(2)Focal 33KX-
-(2)Focal KP165 K3P Kits-
-(2)Focal FP 1.800 Amps-
-(2)Focal FP 2.150 Amps-
-(3)Xenarc 7"TSV Touch LCD’s-
-PROJECT DETAILS-
Old 05-27-2002, 12:38 PM
dysphunxion is a New Registered Member
My e36 has non-folding rear seats, we mounted a W7 in a sealed box to the metal behind the seat. It fires throu the center armrest and is totally sealed off from the trunk. LOTS of BOOM! I also like the fact that it's as far foward in the trunk as possible, keeping my trunk semi-useful and the additional weight closer to the center of the car.
I plan to do the same thing (if possible) to my new M3 when it arrives.
Old 05-27-2002, 02:08 PM
330Ci St.Grey's Avatar
Rides:E36 M3 - Dakar Yellow
330Ci St.Grey is a New Registered Member
FOR GOODNESS SAKES MAN DON'T CUT THE REAR DECK!
I've heard nothing but horror stories about people doing this. Depending on where you make the cuts, you can affect the structural integrity of the rear deck on the car, and in a BMW this can be (depending on the model, I KNOW it is on an E36 M3) an actual structural brace. Cut it and your body structure will go wobbly on you.
Your best bet is to either get a bandpass box or even a ported box. Aim the ports on the boxes out through the opening for the ski-bag on the rear seat (same as cutting out a space behind the armrest). You will get great sound! You could also build a sealed box with the subs angled towards each other (a 90-degree angle) with the angle pointed straight at the opening in your back seat. You should be able to see both subs at an angle through the arm-rest opening. That will also give you a good sound, and the benefits of tighter and cleaner (although not as deep) base from a sealed box.
Old 05-27-2002, 04:14 PM
Rides:e46
silly 3 is a New Registered Member
Punch out the metal behind the armrest. It is actually only tac-welded in several places. It will just pop out and the cut is clean. Looks like BMW did it. The reason why it is only tac welded into place is so if you wanted the ski bag pass through, the DEaler could easily have it done. However, do not cut the rear deck. Sacrificing the integrity of the vehicle for sound. No way. That's idiotic!
Old 05-27-2002, 04:29 PM
Rides:330i
jb330i is a New Registered Member
In my car I had the rubber backing to the rear seats reduced and thin wood placed over. The middle ski rack armrest plate punched out and the whole trunk is dynamated. This helps channel the bass into the car. Bmw's are naturally very insulated. Not a lot of sound comes out of the car. I can honestly only hear it real good when I roll the front windows down. Theese are 2 type r 12" on 2 alpine 1507 1k amps. mids and highs running to a 407 amp. Sounds great. Try different methods.
Old 05-27-2002, 04:40 PM
Who said anything about cutting up the rear deck!!? The hole for my sub is where the rectangular ski hole would have been (never punched out on my car). Even if that flimsy piece of sheet metal WAS vitally important, my sub is actually sandwiching it between the box and itself with a dozen screws making itself sort of a structural brace. It took some work getting it right but I found the toughest part to be modifying my back seat (upholstery).
C'mon guys, give me SOME credit, I am a freakin' engineer!
Okay, ok.....I can see how a jackass with a sawzall can get into trouble. It has to be done with some skill and planning. Yeah some welding was involved, I guess stereo shops won't go that far. I'll stop giving advice now...
The port holes in BEHMER's ride 'could' be trouble.
Old 05-27-2002, 05:19 PM
Rides:e46
BEHMER did...
Old 05-27-2002, 09:59 PM
BEHMER's Avatar
The holes
Trust me I thought of that...I put the 4" holes in the part of the rear deck that was a thin piece of metal there is still the thick structure part with angled metal and what not on all sides. It is kind of hard to explain but if you saw it in person you would understand that it is not a vital part of metal and the holes are small but make a big difference in the db level. I could guarantee that I would not have been able to cut through the structural part with my little hack saw. BEHMER
-Custom HRE wheels-
-Focal Audio:-
-(2)Focal 33KX-
-PROJECT DETAILS-
Old 05-28-2002, 12:58 PM
thanx
Thanx fellas for the input....anymore would be appreciated.
Old 05-28-2002, 03:40 PM
Rides:two four dour family sedans :)
ernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master License
silly 3 is absolutely correct, i did this and ported my previous box through the armrest and it sounded great!
Ernie
ernie-2 dremel tool-0
richard is my hero
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720
