Old 04-07-2002, 08:38 PM
Rides:92 325i
BMW325i is a New Registered Member
Radio Code Problem - Please Help
I have a 325i 4dr, 1992, and today I had to fix my on baord computer because I had a problem with the code. So i disconnected the battery and reconnected it 15 minutes later and now displayed on the radio is code. How do I get this off. I read their is a code card that I need that has the code for the radio on it. However I don't have this card. Then I find I can call the BMW Dealer and they could possibly tell me the code. Is this correct and are they gonna charge me for this. Is their another way.
Jeffrey
Old 04-07-2002, 08:51 PM
Mikedav's Avatar
B Road Addict
Rides:2004 M3 SMG
Mikedav is a New Registered Member
Sounds a bit drastic, but I have heard sticking it in the freezer for 30 minutes does the trick as it clears the memory...having said that whether you want to do that or not is up to you.
Phone the dealer with all the car details you can find from the log book. They should have the key code on record, and the service desk people are usually helpful on such matters. Peugeot and Citroen are at least because I had to do it- and they didnt charge me, they just want to check you havent ripped the stereo off so the ask a few details.
2006 Z4 M Coupe
Old 04-07-2002, 09:13 PM
Punter's Avatar
Rides:1995 Cosmos M3
Punter is a New Registered Member
Haha, sticking it in the freezer for 30 minutes........that's a new one to me.......assuming you don't want to freeze your OBC, you do need the code card, it's usually in the owner's manual somewhere, if you don't have it you can call the dealership but sometimes they are dicks and try to charge you for it.
I'm pretty sure Cosmos is German for "wash me every two days"
Old 04-07-2002, 09:19 PM
Mikedav's Avatar
B Road Addict
Rides:2004 M3 SMG
Well I used to know a guy who was less than level if you get my drift- thats what he and his friends used to do with stereos they had 'obtained'. I didnt believe him till he opened his freezer. As long as you let it defrost first (!), they work fine...
Having said that the other method is much better and shouldnt be a problem.
2006 Z4 M Coupe
Old 04-07-2002, 10:54 PM
ToM3's Avatar
l337 m3
Rides:m3
ToM3 is a New Registered Member
the way that the dealership can retrieve your radio code is by entering the serial number of the radio into their database. you can obtain this code yourself, i can't remember exactly, but i think u can this way: turn the car on (not engine) and hold down the 'm' button until the serial number comes up on the display.
anyway, i can understand how this would be sketchy over the phone and they prob would want u to come in to make sure the radio isn't stolen. they should do it for free unless they're jerks about it. good luck.
Old 04-07-2002, 11:11 PM
Rides:'96 ///M-Powered 332is w/3.46LSD
GENE328is is a New Registered Member
This happened to me when I first got my 328is, before I swapped in my Sony headunit... what you have to do is this: when it reads "CODE", the first thing you must do is start up your car. You have to have the engine running for a full 60 minutes before it will allow you to enter the code. Once the engine has been running for 60 minutes straight, the "CODE" will change to "CODE WAIT..." Once it reads "CODE WAIT...", enter your 5-digit radio code, and VIOLA! it works...As far as getting the radio code goes, go down to the dealership and have them get it for you. This is what I did, it took 3 seconds and they didnt charge me.... What they have to do is take your radio out and check the chassis number on the back of it, then take that number and look in their database to get the 5-digit code... It shouldnt be that much of a pain, if you do it like this, it will definitely work... Best of luck to ya!
S52-powered 332is
Old 04-07-2002, 11:17 PM
Mikedav's Avatar
B Road Addict
Rides:2004 M3 SMG
Run the engine for an hour? Seems a bit odd and impractical...Are you sure? Every car I have ever done it with, just need to turn the ignition to accessory 'acc' to enter the code...
2006 Z4 M Coupe
Punter's Avatar
I just had a factory spoiler installed on my car the other day and they disconnected the battery to hook up the third brake light so when I picked up the car the radio was flashing "CODE". I didn't have to wait 60 minutes though, I just got out the owner's manual, found my code card and entered the code right then while it still said "CODE", worked fine, went straight back to normal operation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
