Old 03-15-2009, 10:21 PM
Rides:e30 m3, e30 325ic, e34 525i
g.ruff561 is a New Registered Member
First install, first flop.
I have a 92 E30 M-Technic convertible. Currently I am running an Alpine head with Alpine type-r 5.25 front fill and custom cut rear fill co-ax. Both fills are the same model. My first problem is, when I turn up the volume, the sound is distorted at high volume. As far as i know, I am running this system off of the head unit power. As a side issue to that, it seems that the volume in the rear is louder. I have to tweek the fader to get equal volume. I do realize that the front speakers are in the kick panels. However there is a distinct differance in volume. My next question is, I want to mount one 10" sub thru the rear seat back. I will remove the rear leather seat back, carpet the exposed metal and build the sub inclosure from the trunk back. I have one Alpine 4 channel amp for mid/high and one Alpine mono to mate with the 10" sub. The rear seat bottom will remain in place. It it rarely used anyway. Any suggestions would be a blessing. P.S. any suggestions on the sub make/model.
Old 03-22-2009, 02:27 AM
Rides:BMW, 328i Coupe, 1995
Scotty89 is a New Registered Member
If you've got Alpine everything else, why not go an Alpine sub as well.
Alpine make very decent subwoofers - they might not be the greatest in the world, but for their price and availability, they will definately compete with anything in the same sort of range.
A Type-R 10" would probably suit you They run 500wrms a piece, so you want a monoblock of atleast 500wrms to get the most out of it.
Old 03-22-2009, 08:58 PM
Sub-Flub
Any advice on the sub configuration??? And what would be your take on the sub build-out????
Old 03-31-2009, 10:51 PM
Sub configuration? 1 sub woofer directly connected to your mono block?
Sub build-out? Like enclosure type or something?
If you are building the box to fit a specified area it would be easier to build a sealed box. Then you will not have to deal with calculating the port width/length/depth etc.
A ported box will sound louder, but the bass will not be as tight. If you want a ported box, it would be easier to buy a pre built one.
Old 04-01-2009, 07:28 PM
The sub configuration.
As stated I am considering finding a way to mount the sub by making a cut-out in the metal rear seat back, and mounting the sub in a sealed box so that it fires into the passenger compartmant. I prefer a tight bass. A solid thud not a lingering boom. Then carpet the remainder of the rear sheet metal with carpet. I dont know why but it seems to me that as much money as a good sub costs, you are losing a lot of your bass by having the sub fire backwards and out of the trunk. A lot of rattle for nothing. With or without dyna-mat. The rear passenger seat bottom will still be used. My bordeaux rides the back seat, top down and sunglasses. she is a roit. I like your idea of staying with the Alpine name brand. However, I am looking at one jl audio 10w7, or two jl 8". Thanks for the feed back.
Old 04-01-2009, 11:46 PM
I am not too sure, but I definitely wouldn't go cutting up your seats.
I can see that you don't want to seal it off in the boot compartment (I ride with the rear seats folded flat, so the cabin + boot are not sealed from one another), as it definitely does suppress the kick quite a lot.
I also wouldn't go building the box onto the rear of the seat (unless they are fixed in a 'vert? I wouldn't know...)
You should build a sealed box, and put it in the boot, and work about a port/vent into the passenger compartment, hopefully something not so permanent/irreversible.
Also, firing the sub backwards - it definitely a good idea, even just to try it out and hear for yourself.
I honestly thought it was stupid too, until i tried it. When the sub + port fire backwards, there is much more bass loading gained because the sound bounces off the inside of the boot. You will gain more rattle, but also more bass - then if you dynamat, you can eliminate most of the rattling and gain more bass. Definitely worth the extra effort though.
Also checked out the JL audio 10w7 - optimum RMS power is between 250 - 500wrms, and the reviews seem to be that its a great driver - though its fairly pricey for its size and power I'd think. It sure does look like one tough mofo though, I sure hope it doesn't disembowel any passengers riding in your rear seats.
EDIT: Looking at the specs of the 10w7, it says nominal impedance is 3 ohms, and DC resistance is 2.75 ohms. From that I am gathering that its 3 ohms... I'm not familiar with any 3 ohm setups, not sure how it will wire up to the alpine amp. I guess you will have to aim for a 2 ohm setup on the amp if you can - From my understanding, you might cause damage to the amp if it runs without enough resistance in the circuit (e.g, a 4 ohm amp setup rating, with only 3 ohms resistance from the sub).
Old 04-02-2009, 12:15 AM
Which alpine amplifier is it you are using for the sub? You may be able to find a more suitable subwoofer to pair with it.
Old 04-13-2009, 06:51 PM
bmw528i's Avatar
Mr. Clean
Rides:Titanim Silver E39
If you have an amplifier that is 2ohm stable, I can't imagine it would be much of a problem. However, if you want a 10w7 I think you should strongly consider a JL Audio 500/1 as they are stable and consistent from 1.5ohms to 4 ohms.
Old 04-17-2009, 08:28 PM
Thanks for the feed back. I am not cutting the leather seat. I will be cutting a square section the size of my sub box out of the medal panel that seperates the rear seats and the trunk. The box is already made and 1 10' sub is all I would need. By the way, the box is non-ported and I now have to figure a way to mount the box mid way up the sheet medal back and low enough not to interfere with the power top operation. Fixing the sub box flush with the sheet medal and stablizing it enough so it does not shift around is still going to be a major challenge. The back top section of my rear seats will not be used. A good quality carpet will be used to give a custom look to the rear seat back and trim around the sub box cut out. Hit me back with any ideas. Thanks, G.
Old 04-18-2009, 11:31 AM
Rides:90iC, , 91318iS, 88M3, 98M3/4
MachineHD is a New Registered Member
check out this thread for custom e30 subwoofer enclosures
The New Subwoofer box FS thread - Page 13 - R3VLimited Forums
cheers!
Old 04-18-2009, 10:55 PM
My problem is that I do not have a center armrest in my 92 E30 Mtechnic.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
