Old 03-03-2009, 03:07 AM
Rides:1992 E36 320i
russelljb is a New Registered Member
E36 Sedan Sub Position Advice
Hi fellow DTMers.
I own a 320i sedan in Australia and have been upgrading the audio.
Tonight I installed the wiring for a sub and amp and have just been playing around with where I might position my sub.
I errrrrrrr, gave myself the ski port option and the box that my sub is in fits perfectly up against the back of the rear seat with the sub facing towards the cabin through the ski port. This is the best position for me in terms of using up space in the boot. It is perfect really.
What I want to know is will this lower my potential bass as I was told it is better to face the sub towards the rear of the car, however I have seen many setups where the sub is facing through the ski port.
Advice?
Thanks,
Russ.
Old 03-05-2009, 03:49 PM
Rides:1995 BMW 325is
Duke131 is a New Registered Member
I'm also curious about this. Anyone?
Old 03-08-2009, 06:31 PM
Rides:1992 E36 320i
Hmmm these forums seem a little stagnant!
I am pretty happy with having the sub pointing in to the cabin through the ski-port. The box I currently have the sub in is way below the recommended volume (recommended 1.25 cubic foot and the box is only 0.7) and the angle for the back seat isn't right so there is a fair bit of gap between the opening and the actually speaker. I am soon to be getting a new box that is 1.2 cubic foot and sits against the seat.
Sounds great though!
Old 03-12-2009, 11:42 PM
Rides:1996 BMW 328is Metalic Montreal Blue
Crispy222 is a New Registered Member
point the sub towards the rear and listen to the reflected sounds. It will help fill in the lower tones IMO and experience. After positioning the box facing front or rear, play with swapping the the pos (+) and neg (-) terminals. You are trying to match the wave's phase with the interior speakers.
People face it thru the hole for looks only.
Old 03-22-2009, 02:31 AM
Rides:BMW, 328i Coupe, 1995
Scotty89 is a New Registered Member
Facing the subwoofer + ports to the back of the trunk will give more bass loading - I never intended to do it myself either but after I comparing forward/backward mounting, I haven't looked back since.
Definately sounds beefier, though if you haven't insulated/padded the trunk and panels, it will cause alot more audible vibrations.
Old 04-23-2009, 05:50 AM
Rides:BMW 320i 93
Baxy is a New Registered Member
hey mate just givin u my 2 cents worth, ive got my sub(15inch) located in the wheel well. just had to do a few little mods to make the box fit, but it slipped in there nicelyand sounds a treat, only bad thing is that you cant run a spare in the boot......
just a pic for ideas, its not award winning but its alright. Slammed BMW 320i Bagged on 20's.... - goulburn, AU
Old 04-28-2009, 05:45 AM
rf90's Avatar
Rides:BMW E36 318i
rf90 is a New Registered Member
in my opinion to get the best bass in the cabin is to have it facing through the ski port!
the further back it is the less you will hear in the cabin and the more distortion you will get from boot rattle etc, i fixed this with some sound deadening but it's still not 100%. im running 2x12 800rms each
Old 04-30-2009, 07:02 PM
Maz Maz is offline
Rides:Bmw 328i
Maz is a New Registered Member
At the back of the boot firing into the boot lid is definitely loudest.
Then allowing the bass to flow into the cabin.
This is called "rear loading"
Old 05-10-2009, 09:06 PM
Rides:BMW 328i Convertible 98, BMW 525i 95
edge747 is a New Registered Member
Face it in toward the cabin as the BMW trunk is tight as a vault. What sub/amp did you get?
Old 08-08-2009, 10:29 PM
E30stain's Avatar
Sherminator
Rides:'95 Triton turbo diesel
i did this in my old e36 323i. get a flat plywood board (15mm is indestructable) and mount the sub in it so that it faces the cabin. have the rear of the sub exposed in the boot. screw the board into the metal around the ski hole, depending on the size of the sub you might need a couple of bits of wood as spacers so it clears the ski hole edges, wont need too much. stuff some rubberised foam into the gaps to make it air tight.
That creates what i think is the clearest bass with the armrest down. can be done neater, i had some grey carpet laying around so i covered the back of the board and had the amp screwed on the back too. my 12" sub needed some sort of spacing but not much. i found using the whole boot as an enclosed box was really good especially with the bmw sound proofing under the seat and good condition boot seals. plus mounting it like i had it left almost as much boot space as what i started with. I think this only works on the sedans as the seats dont fold down.
makes for a great massage seat too!
Old 08-14-2009, 10:44 AM
Registered User
Rides:328i
Undrstm8ed is a New Registered Member
All in all just to add my $ .02 Bass frequency's themselves are recorded mono left and mono right simply because its most of what you hear below 120 cycles (hz) is NON-directional. Which is WHY you can hear it coming down the street from any direction. the higher the frequency the more omni directional and directional the sound becomes.
What your hearing between front and back loading is reflection and time dealy...
Old 08-20-2009, 04:36 AM
The part you mention about directional sound from a subwoofer is true, yes. This is also because the lower frequencies have a longer wavelength, and can penetrate through objects better.
That is why you can often hear the bass/rumbling outside of clubs or home theatre rooms. Because the bass has much better ability to penetrate with lower frequencies than say a tweeter.
This does not mean that rear/bass loading from firing it backwards into the trunk, is false.
Just go out to your car, and turn your sub around. Listen for yourself. It IS noticeably heavier when firing backwards into the boot.
Many just refuse have it firing backwards because they seem to think that their subs will be seen more by people sitting in the car, or look more impressive. If you want people to see what is producing all this mad bass, go and open the trunk. How hard is it?
Also @ E30stain, I believe what you are trying to describe is an infinite baffle setup. This means that the sub will use the entire sealed boot as its enclosure.
For a 12" subwoofer, the capacity of the trunk is far far too great for the optimal performance of any typical 12" subwoofer driver. Even for a ported 12" enclosure, the entire boot is far too big.
Yes, it will give bass, and yes it will sound better than having the sub flopping around free-air, but it isn't really a way to achieve the most out of your sub.
Edit: and as for time reflection/time delay - yes the reflection is helping create the bass loading... and as for time delay, well, don't bother getting anything bigger than an 8" driver if you think that time delay is going to mess up your sound quality.
Subs need heavy cones with lots of power to move considerably more air than woofers or tweeters - because they are heavier and cannot "accelerate" or oscillate as quick, the heavier cones therefore are a lot less articulate/accurate in reproducing sound than the woofers are. That is why a 15" is not as tight/punchy as a 10" driver.
The sound delay from the sound waves traveling from the sub, to the boot lid and then back in to the cabin is negligible. Most of the time, the sound delay between the sub's sound in relation to the other speakers is caused by using a larger driver (say 15" or 18") without sufficient power to drive it, and in an oversize enclosure. That is when you will hear sound delay and booming/muddy bass.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
