Old 01-18-2006, 09:04 AM
The Flying Finn
Rides:BMW E36 316i -93
Karalahti is a New Registered Member
JVC KD-S8R installation ??
I've been trying to install a new headunit to my friends car, without any success.
The problem is with wiring. Unit itself works fine, goes on in Acc position and off when key is removed so it looks like everythings ok, but the player loses all the memorized radio stations ?!! Could someone with JVC head unit please tell me how it should be wired ?
Istallation manual can be found here (.pdf):
JVC KD-S8R
So far the wiring is as follows:
+12V "live" goes to A4
+12V "acc" from lock goes to A7
GND "ground" goes to A8
Thanks !
- Custom modified front bumper
- Rieger front spoiler lip
- Rieger rear bumper
- Rieger side skirts
- Angel Eyes
- H7 Super Fog lights
- Clear corners and side markers
- Smoked rear tail lights
- Painted Bumper and side moldings
- Painted front grill
- M3 Mirrors
- Lowered -35mm (orig.shocks. H&R Springs)
- Custom exhaust with double
tailpipes
ICE
- Sony CDX-MP40 head unit
- Pioneer 6,5" 2-way speakers doors
- Pioneer 5,25" 2-way speakers rear
- DLS 712W Sub woofer
- Autostudio BC5.50 5-channel amp
Old 01-18-2006, 03:45 PM
DaSaintly1's Avatar
OO-[][]-OO
Rides:BMW, E36 318TI Sport - Supercharged, 1997
DaSaintly1 is a New Registered Member
there will be a memory power wire (A4) that will need to be connected to a constant power line.
that way, when the car is switched off it is still supplying a small bit of power to the head unit to keep it's memory alive.
my guess is that the location that you have A4 connected to is not a constant power source. i.e. when the car is off does it have power? re-check where A4 is connecting.
Old 01-18-2006, 10:44 PM
The Flying Finn
Well, the A4 is connected to a "live" source at the moment so I don't know what possibly could be the problem??
When I first removed the unit, A7 & A5 had a live feed, but if I understood correctly, according to manual, A5 is meant to be used for a motor antenna, or amps etc.. So it should be an output, not an input ??
- Angel Eyes
- M3 Mirrors
tailpipes
ICE
Old 02-12-2006, 11:24 PM
cbouchez's Avatar
AC SCHNITZER
Rides:92 325I,94 325I, 90 GLI VW,
cbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master Licensecbouchez has achieved their Master License
did you check the remote wire? It should be blue on your harness. Conect it to power.
Old 03-09-2006, 01:08 AM
Rides:1996 BMW 328is Metalic Montreal Blue
Crispy222 is a New Registered Member
The remote wire from the head unit should not be connected to contast power. If you do this and run a CD it possibly will fry out the preamp of your deck. You should get a LCD/light tester or a multimeter and test to make sure the wires from the car are what you think. Make sure those are correctly the contast and acc/running leads. Many people reverse the two out of the car. Its very common.
Old 04-01-2006, 12:13 PM
Chin00k's Avatar
Rides:'94 BMW E-36 316i Compact
Chin00k is a New Registered Member
usually the red cable goes to power, its the one that even if the keys are out it gives power. yellow goes to "-" the one that gives power after you turn your car key. if you connect it that way and it still loses memory its the unit that is messed up.
DIRTY OR NOT, STILL A BMW, NOT A FIAT;P
Old 04-01-2006, 12:50 PM
cbouchez's Avatar
AC SCHNITZER
che this out.
Left Rear
yellow black +
yellow brown -
Right Rear
blue black +
blue brown -
Left Front
yellow red +
yellow -
Right Front
blue red +
blue -
Ground
brown
Power
from fuse 12, 7.5 amp, hot w/ accy on = violet white
hot at all times
from fuse 28, 30 amp = red yellow
from fuse 21, 7.5 amp = red green
antenna power is white
Old 04-01-2006, 01:27 PM
Here is the pin out sheet I have. Its worked for me.
If the link doesn't work this time I'll redo it another way
Old 04-04-2006, 02:32 AM
Old 04-06-2006, 07:01 AM
Chin00k's Avatar
dude, this is how my old connector looked like, my stock 94 bmw radio had it.
Old 04-06-2006, 12:52 PM
This is what my 95 325is and 96 328is had.
Old 04-07-2006, 10:34 PM
Chin00k's Avatar
but it needs to be replaced with the ISO connector
Old 04-18-2006, 11:00 PM
what do you mean by ISO connector?? The new HU's connector??
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597
