Old 06-12-2005, 06:37 AM
Rides:97 Jetta VR6 R.I.P 1991 Mercedes 190E
EuroTunedVR6 is a New Registered Member
sub/amp trouble
i have a 12" infinity sub with a 4 channel infinity amp, front to channels go to my componets in the back and the rear channel is bridged to the sub. when i turn it any higher then 2/3's on the headunit the amp shut down for a second and goes it to protect. the gain on the amp is 1/2 way up and bass boost as well. do i need a cap or a bigger power wire to stop this from happening????
Old 06-12-2005, 07:33 AM
325i racer
Rides:93 325i
trevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Membertrevor 325i is a New Registered Member
sounds like the amp is clipping too low of a ohm load possibly how is the amp hooked up bridged or what?
Old 06-12-2005, 07:34 AM
carstereopro's Avatar
What impedence is the sub?
If it is a 2 ohm, or if it is a dual 4 ohm and you have it wired parallel to the bridged circuit of the rear channels of the amp, the impedence is too low.
If it is a 4 ohm single coil, you might want to check your grounds on the amp and at the chassis, and even at the battery and to the chassis ground for the battery.
Phil Chartier
Carstereopro
Old 06-12-2005, 10:19 AM
its a 4 ohm single voice coil sub, so 1 channel of the amp bridged would be the proper ohm level for this sub?
http://www.crutchfield.com/S-eqKKRc9...20&I=108R7541A
thats the amp
Old 06-12-2005, 06:04 PM
the amp ground wasnt bare metal there was paint so i wire brushed it till it was all nice and shiney, same with the batt. terminal and connector, ran bigger wire from the amp to the sub but still no luck
Old 06-14-2005, 10:07 PM
i think i figured out the problem, when i bridge just the rear channel then it bridges the front one to and i have 2 speakers on the front so its a indenpendance problem
Old 07-12-2005, 04:51 AM
b3m2w5_95's Avatar
Rides:1995 BMW 325i
b3m2w5_95 is a New Registered Member
just put your sub in one channel (not bridged).
Old 07-14-2005, 06:15 PM
keeptheuroalive's Avatar
Rides:1995 325is "M3"
keeptheuroalive is a Permit Holder
just buy an amp that was only one or two channels because if you run enough power to your sub which should be around 700 watts RMS (correct me if im wrong) you run the risk of blowing your rear speakersbecause very few components can run at 350 watts peak. so my advice is to use the amp for all of your speakers (and why do you want your rear amped if your fronts arent) and buy a bigger single channel amp for your sub
Old 07-16-2005, 12:21 PM
theres gain control for each channel so i can turn the rears lower then what the sub is, and the rear speakers are componets and the fronts are 3 1/2's that only handle 35 rms so theres no point in amping them
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732
