| Can you please provide a little more information? Is this the stock head unit with stock rear speakers or is this an aftermarket system. Either way it sounds like a classic bad ground issue. Check all your grounds on your amps (If you have aftermarket one) and make sure you are using the shortest cable possible. If this is the stock head unit check the ground on the harness and hookup a second case ground if necessary.
