Old 10-06-2003, 11:06 AM
Rides:95 Hellrot //M3
mantic6t9 is a New Registered Member
Adding amp to factory system.. Which plug and wires?
I though i had this all figured out and i did but i had it figured out for the HK system which i don't have. I have a 95 m3 non HK.
What i want to do is splice in a set of RCA cables into the radio connector. This will give me a signal directly from the head unit. My problem is that i don't know what plug or wires. Do i want to splice into the rear speakers or the fronts? If you can help please do.
Here are pics of the plugs i have.
And does anyone have a clue what this is?
Old 10-07-2003, 05:01 PM
Rides:1996 Boston Green 328i
BrianW is a New Registered Member
it looks like a termination (?) block if you ask me, not really sure, cant tell much from the pic :-/
as for the wiring, here i hope this helps (sorry for the large size and just ignore my drawing i got there, :P
dtm wouldnt let me add it to my photo gallary so i had to upload it offsite
Fatal error: Allowed memory size of 8388608 bytes exhausted at (null):0 (tried to allocate 3504 bytes) in /usr/local/www/www.dtmpower.net/ppost2/image-inc.php on line 28
Fatal error: Allowed memory size of 8388608 bytes exhausted at (null):0 (tried to allocate 11 bytes) in Unknown on line 0
Old 10-22-2003, 11:18 AM
Rides:1996 BMW 328is
raceyBMW is a New Registered Member
That connector is prewire for the cd changer option, I think. Just follow that diagram from the bentley manual, it shows exactly what everything is.
Old 10-22-2003, 11:39 AM
Thanks everyone I figured it out. I installed everything last week and it works great. The only problem i have is that bass causes my cd changer to skip.
Old 01-01-2004, 01:10 PM
Dormant
Rides:94 ///MTechnic (holidays)
///MT is a New Registered Member
Back from the dead. heh.
anyways, Mantic, did you use the stock headunit? What exactly did you add/change?
My sister just bought an amp and 2x10"s for my car (she drives it while i'm away at college) and i'm looking for a bit of guidance on how to install them before i go in and try to figure it out myself. If you have any pictures/tips/advice/tutorials/resources/whatever on your install, could you please post it? thanks!
///MT
Old 01-01-2004, 01:13 PM
Yeah man i used the stock head unit and spliced into the reciever wires. It works fine and was very easy to do. I used the diagram posted above and soldered in the corresponding wires.
Old 01-01-2004, 01:18 PM
Dormant
i'm getting the old red x's
Old 01-01-2004, 01:22 PM
sorry i wasn't in this thread anyway. I searched and found it though. Here is the link http://www.unofficialbmw.com/e36/ste...-pinouts-a.gif .
That matched my car correctly. If you have an HK system the wires are different. What year is her car?
Old 01-01-2004, 01:28 PM
Dormant
okay. i had that diagram. um, so did you run RCA cables from the headunit to the trunk? Did you tap into the "radio connector" or "amp connector" harness? You just had 2 wires coming out of the connector at the rear woofer pins?
I actually don't know if it is the "HK" system, but it is the "premium" 11 speaker system. I'm pretty sure that harness is correct though.
The car is a 1994 325is ("M-Technic")
Thanks.
///MT
Old 01-01-2004, 01:37 PM
I spliced into the radio harness in the trunk. I ran RCA cables from there to my amp.
Old 01-01-2004, 01:46 PM
Dormant
cool. thanks. i'm going to go poke around this evening and might be back with more questions later
Old 01-01-2004, 01:56 PM
Sounds good.
Old 01-02-2004, 08:47 AM
Dormant
did you install any sort of crossover network? I found the harness I think I need (coming straight from the headunit) and can tap into the left and right rear signal, but i dont know if that will somehow adversely effect the sound to the stock speakers...
///MT
Old 01-02-2004, 08:58 AM
It's should be fine. I removed my left rear speaker in an attempt to get more bass into the cabin. I still have my right rear and it sounds fine.
Old 01-02-2004, 12:11 PM
Dormant
yay! it works. thanks Mantic for the tips
now i just need to buy a sub or two and build the enclosure.
///MT
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505
