| well i assume it would be the exact same as the install on my CDA9815 and any other CD Player, just connect the wires to the respective wires, and you might want to make sure you connect the alpine's remote wire to the antenna wire on the bmw harness, that way your amp will be on always when your cd player is on
if you want to take the time and do a nicer job (less wire to shove in also) you might pull the clips out of the harness, and then solder the alpine's harness wires into the clips and then stick them back into the harness... i wouldnt recommend doing it unless you know you can do it correctly and can get them back into the correct holes and solder the wires on nice and strong |
