| Brian -
The dimensions you want is LESS than 16 inches tall, LESS than 30 inches wide, and LESS than approximately 18 inches deep (this is if you are trying to fit it b/w the 2 wheel wells).
I know for a fact you can fit two SEPARATE Qlogic 12 inch boxes b/w the two wheel wells like I have in my green car. You can also fit a Vented enclosure with a single 12 back there as well. This is going in my silver one ...
Sealed -- two 10's would be the maximum you could really fit made to proper specs ... (again, b/w the wheel wells). IF you don't care if it sticks out in your trunk, the q-logic dual 12 box will fit as well. Again, I know for a fact ... I have like 3 boxes lying around here ... but, use those dimensions to gain an idea ... |
