Old 01-09-2003, 03:03 AM
Rides:1993 BMW 325is
BMR616 is a New Registered Member
Head Gasket leak....effects of it?
What are the effects of a head gasket starting to leak? Performance affected? Any info or advice would help. How can I tell if it is leaking?
Thanks.
Old 01-09-2003, 11:23 AM
tdc's Avatar
tdc tdc is offline
Rides:a white car
Loss of oil pressure, power loss, overheating, just to name a few.
You can tell by the oil covering your block. Usually it is from the corners.
still around
Old 01-09-2003, 12:00 PM
E31's Avatar
E31 E31 is offline
Techno Racer
Rides:BMW 850i (E31) 1991
E31 is a New Registered Member
Oil consumption will increase, white smoke from the exhaust, coolant being used up, the obvious external oil leakes, could hydro lock a piston tearing the entire engine apart, could misfire or take a while for the engine to start, the plugs have encrustations in them....what else....
Old 01-09-2003, 12:54 PM
Rides:1987 Bmw 325 4 door
NightHawkBmw is a New Registered Member
"Loss of oil pressure, power loss, overheating, just to name a few.
You can tell by the oil covering your block. Usually it is from the corners."
"Loss of oil pressure, power loss, overheating, just to name a few."
and the other symptoms explained by the italian guy.
also, check for water pouring out the exhaust, and check your oil, if it looks watery or has a chocolate milk look to it, that could be a blown head gasket. also, Loss of compression, smoke, as explained earlier, car sounds rough and likes to stall (mine did anyway)
Old 01-09-2003, 01:44 PM
alphaoenz's Avatar
Penz Member
Rides:asdf
alphaoenz is a New Registered Member
Burning coolant, milky oil, clouds of white smoke, overflowing coolant resivior.
Old 01-09-2003, 09:31 PM
Hmm...i think i'm starting to have some leak......expensive to fix?
Thanks.
Old 01-09-2003, 09:38 PM
Another God Damn M3
Rides:BMW, M3, 1998
EstorilBlue98 is a New Registered Member
shouldnt be. why do you think you have a leak?
white smoke is water is getting in, black smoke, oil is getting getting in...
it would cost a good amount to simply replace the gasket, prolly like $300~$600
Old 01-09-2003, 09:59 PM
BoominBenz's Avatar
Benz Roller
Rides:Mercedes C280
BoominBenz is a New Registered Member
Get it dealt with quickly! Blown headgaskets can lead to cracked heads.
Old 01-10-2003, 12:38 AM
See a little oil on the corners. =(
Doh....I should get it fixed sometime.
I have a 1993 325is with 105k miles...likely?
Old 01-10-2003, 12:46 AM
317hpOBD1M3's Avatar
Rides:95 m3
317hpOBD1M3 is a New Registered Member
repair it quick man.. my friend had a head problem on his integra.. and he ignored it.. and boom there went his entire head. Never fool around when ur gettin engin probs.
Old 01-10-2003, 11:17 AM
E31's Avatar
E31 E31 is offline
Techno Racer
The gasket change is simple. All you need is some time. Save the $ and just get the gaskest from the net. If you are an average mechanic, you can do it no prob. It is only a matter of removing the stuff that is in the way. Make sure that you torque the bolts down to speck and take your time. Hell, I have changed entire engines out, intake manifold gaskets, rings, clutches...just take your time. If you don't feel confident, have a shop do it and it doesn't have to be a BMW dealr for this job.
Old 01-10-2003, 12:08 PM
Alright. Thanks.
What other parts should I be getting..juss the head gasket?
I might order online...prices are probably lower.
Old 01-10-2003, 02:20 PM
Matt's Avatar
matt
Rides:1990 325i
the online places usually sell headgasket sets that include all the gaskets you need to do the job. you need a shop manual for your car that gives directions and specs. there is a lot more to it than the others have described, but you can still do it yourself.
Old 01-10-2003, 02:52 PM
Another God Damn M3
Rides:BMW, M3, 1998
dood, if you dont know what a head gasket leak is and what it does i would HIGHLY reccommend you NOT change it yourself.
and don't tighten it to speck... try spec. or specification.
Old 01-10-2003, 06:17 PM
DOHC Vanos
Rides:95 M3 Kompressor, 94 318 Kompressor, 89 M3
GQ_Style is a New Registered Member
The do-it-yourself gasket is the valve cover gasket, located on top of the head. The take-it-to-a-shop gasket is the head gasket located below the head between the head and block. Both gaskets are gaskets for the head, but big difference.
Thread Tools
Display Modes
DTM Power © 2016
