Register FAQ Members List Calendar Mark Forums Read
Old 01-24-2002, 06:59 PM
Rides:C32 AMG
Region: Asia
328bimma is a New Registered Member
brembo gas slotted or ATE slotted rotors?
i currently have the zimmermans... and its almost time to replace them... wondering which set should i go next?? i have had the brembo cross-drilled... and they were nice... but now i want to try something differnt! any opinion is welcome guys!
Jerry
Old 01-25-2002, 12:11 AM
Rides:1994 Dinan 3 - Sold, 1998 M3/4
dinan3er is a New Registered Member
Exclamation I got the ATE's
I put them in about a couple hundred miles ago, but I drove pretty hard on them. They work really well (coupled with Porterfield R4S pads) and even make the car look better with the cool eliptical slot design. Anyway, if you have any questions, just reply.
Drive Safely,
Dinan3er
1998 BMW ///M3/4 - a few Dinan goodies
Old 01-25-2002, 11:43 PM
Rides:C32 AMG
Region: Asia
will they last long?? and... since i have the porterfield 2...so... just wondering how it works on it?
Jerry
Old 01-26-2002, 01:10 AM
Rides:1995 Dinan 325is
95Dinan3 is a New Registered Member
I've had the ATE's on front for about 10,000 miles now with 0 problems. I really like them so far, but I don't get on them that hard yet.
You must be fast, because I was flying when I passed you!
Mods:
Dinan Exhaust
Dinan CAI
Dinan Chip
Dinan Throttle Body
Borbet 17" Wheels
Khumo ecsta 712's
Nakamichi MB-75
Old 01-26-2002, 02:59 AM
Rides:C32 AMG
Region: Asia
howz the stoppin power???
Jerry
Old 01-26-2002, 03:04 PM
I have a European M3 3,2 supercharged. 515 hp at the flywheel.
I use Ate powerdiscs in the front and rear.
The front pads are from Pagid RS 19, and the rear pads are from Pagid RS 9.
The one and only problem is with the noise coming out of the discs when I drive softly. If I push the brakes, no sound comes.
515 hp Euro supercharged 3,2M3 from TURKEY
Old 01-26-2002, 03:10 PM
Rides:C32 AMG
Region: Asia
dat sounds weird... sound when u drive softly?? but... no noise when you push the brakes???
Jerry
Old 01-27-2002, 04:24 AM
Rides:92 325i
mahkeey is a New Registered Member
I love my ATE! other than the rotors rusting, I love it! I have the Ate power disc for the front and bmw stock rotors in the rear with metal master brake pads all around.
Old 01-27-2002, 04:35 AM
Rides:C32 AMG
Region: Asia
the rotor rusts too??? dang it... that is goin to change my mind a littlebit!~ any knows about EBC rotors??
jerry
Old 01-27-2002, 11:48 AM
paul e's Avatar
Rides:'99 SC M3
Hi Jerry, That's some list of mods! Tell me, since youve had the Zimmerman Cross drilled rotors, why are you replacing them, ie, were they unsatisfactory in some way? And second, I didnt see that you have forced induction, so why then would you want/need an Adjustable Rate Fuel pressure regulator?
Paul E
Old 01-27-2002, 04:00 PM
Rides:C32 AMG
Region: Asia
the zimmerman CD rotors i have had for about a year now... and... it is warping a little bit~ im not unsatisfied... just want to try everything out!
as for the fuel pressure regulator~ you don't reallie need to have force induction to have it! it just gives me the juice when i am at high RPM~
Jerry
Old 01-27-2002, 07:48 PM
Rides:92 325i
jerry
hey jerry, only the hat part of the rotor rust. you can fix this by using a high temp engine paint. hope that help
Old 01-27-2002, 09:02 PM
paul e's Avatar
Rides:'99 SC M3
Jerry, With forced induction, you need it because the stock computer program fuel maps dont allow enough enrichment under WOT. But since you dont have forced induction, you are implying that whatever program youre using isnt rich enough under WOT or high rpms as you say..What I dont understand is why your program module isnt providing you with enough fuel...We know that if you are going beyond stock equipment in supplying substantial amounts of additional air to your manifold, your standard fuel program will need some help...What are you using in your case which makes this necessary? Also, with a Rising Rate Fuel regulator, it works because it only comes on at WOT, when you are running only in Open Loop, so the DME isnt going to choke on the additional fuel being measured by your O2 sensors. But if yours isnt a RR design, then how do you keep the additional fuel from screwing up your closed loop measurements, causing CE lights? Just trying to get a better understand how youre using it...
Paul E
Old 01-28-2002, 05:11 AM
Rides:98 M3
TurboM3 is a New Registered Member
How do you know when your rotors are warping?
Thanks
Mark
Old 01-28-2002, 10:05 AM
Old and wise
Rides:95 ///M3sc, 03' SL 1000R Falco, '10 Mini S
You go Paul! That is some list of mods. But there is nothing to indicate the need for a new regulator. But I'm just an engineer, what do I know.
Rotor warpage is felt as a plusing through the pedel, and / or by a possible vibration in the steering wheel.
Thread Tools
Display Modes
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171
